GSXR 5/8 Master Cylinder Retrofit
Old Aug 13, 2008 | 02:33 PM
filter69's Avatar
Thats Mr Dill hole to you
So i decided to put the gixxer M/C on after the 6 pot tok. calipers used the original hawk lever. Had to dremel some off the handle around the brake switch otherwise fits fine.
The lever is super firm now and i guess ill get used to it. But i was gonna drill and tap the
M/C to accept my stock hawk Resivoir (gixxer one looks stupid and is way to big )
any one have ideas where to mount this b4 i start drilling and tapping . See attached pics
On a Side note im PISSED!!!!!!! i nicked my f'in tank while doing this dropped wrench on the tank...PHack!
Oh well any tips tricks other ideas appriciated Thanks
Attached Thumbnails GSXR 5/8 Master Cylinder Retrofit-100_5487.jpg   GSXR 5/8 Master Cylinder Retrofit-100_5488.jpg   GSXR 5/8 Master Cylinder Retrofit-100_5484.jpg   GSXR 5/8 Master Cylinder Retrofit-100_5485.jpg   GSXR 5/8 Master Cylinder Retrofit-100_5495.jpg
Old Aug 13, 2008 | 08:43 PM
Gregw's Avatar
Ack! Sorry about the tank.
I've a different setup, but here's what I did. The pivot pin for the lever is hollow on my Brembo. I bent up a piece of aluminum and drilled a hole in each end. I tapped the pivot hole a used a really small screw to attach the alum to the MC. The alum piece looks too tall in the photo, but the reservoir is much smaller than the stock Hawk's.
Attached Thumbnails GSXR 5/8 Master Cylinder Retrofit-mcres.jpg
Old Aug 13, 2008 | 09:01 PM
filter69's Avatar
Its an idea i was wondering would not a zip tie work in place of that Monster hose clamp ?
and i saw the ford key layin there now your in trouble
Old Aug 13, 2008 | 10:12 PM
Gregw's Avatar
The clamp is gone now. The spring clamp I originally was using fired off the end of my pliers (found it outside under my truck a few days later).That clear hose came with the MC. After about three days, it started sweating brake fluid on the outside. I've replaced that as well. Moral: what's worth doin', is worth doin' twice.
Old Aug 13, 2008 | 10:15 PM
filter69's Avatar
My motto is as follows "If its worth doing its worth OVerdoing"
Old Aug 13, 2008 | 10:25 PM
Gregw's Avatar
My dad had the same motto and boy did he prove it.
P.S. I'm ignoring that Ford comment
j shizzy wizzy
Apr 7, 2009 09:01 PM
VTRumble
Aug 1, 2008 09:58 AM
VTRumble
Nov 11, 2007 09:45 AM
nineighthawk
Apr 26, 2007 10:04 PM
CNI Dawg
Mar 19, 2007 02:57 PM
