Grab this you SH clucthes!
Old Feb 27, 2019 | 08:39 AM
  #31
I have experienced the clutch grab and chatter for the longest time... learned to live with it, but ain't fun when that happens, I did look to try the conversion to clutch cable, but go find varadero parts in the states... seems just easier with Oberon.
So, I did end up ordering directly from the factory as well after reading this thread and just received the the Oberon couple days ago, within 4 days of the order shipped from the UK, really took me by surprise how fast it came :-)
Can't wait to install and test it.
Old Mar 21, 2019 | 05:44 PM
  #32
I finally got to test the clutch with the new Oberon slave cylinder.
I most definitely noticed the difference immediately, much smoother engagement and easier control, absolutely love it, don't know why I waited so long...
I took the bike for a 2 hour ride all through back roads, I was really pushing it and the clutch was working really great under different conditions of accelerating and decelerating, worth every penny!
Also, Oberon England sent it in 4 days which took me by surprise, I must say kudos for the super quick service as a regular order.
Old Mar 24, 2019 | 03:06 AM
  #33
Good to see you are happy.
I haven't had any probs with my clutch except a few groans when getting right up it.
if the symptoms persist I will follow your route.
Thanks for the heads up !
Old Apr 26, 2021 | 02:35 AM
  #34
CJVTR00's Avatar
CJVTR00 is on a distinguished road
Angry
Oberon clutch delivered and installed.
Doesn't make a rat's @rse worth of difference.
No change, zero, zip nilch nada..........
Old Apr 28, 2021 | 07:58 PM
  #35
Then you did something wrong.
Old Apr 29, 2021 | 01:20 AM
  #36
CJVTR00's Avatar
Straight swap for old slave, system flushed, bled and still grabs like a two year old in a lolly shop.
Old Jun 3, 2021 | 04:56 PM
  #37
Question for those that have installed an Oberon slave: If you used the stock line or a braided aftermarket line with similar/same as stock banjo fitting on the slave end, how did it match up to the Oberon? Would a different banjo fitting angle or length have been better?
Old Jun 6, 2021 | 08:44 PM
  #38
Straight swap, just did a good flush to the old fluid and bleed the system, works very well.
xeris
Mar 2, 2020 09:02 AM
HawkRider98
Aug 19, 2013 07:18 PM
Highfly
Mar 29, 2012 09:32 AM
skycam
Sep 10, 2010 03:35 PM
JayBird217
May 27, 2008 05:05 PM
