Gauge HELP
Old Jan 23, 2009 | 11:20 AM
ericb269's Avatar
kneeedragger
ericb269 is on a distinguished road
Gauge HELP
hey guys this is probly a dumb question but here goes anyway. My tripometer resets every time I turn of the bike any ideas???? please help
Old Jan 23, 2009 | 11:46 AM
One of the fuses are for the "backup power" check that... If not that, check the condition of the battery and charging circuit... R/R and the rest...
Old Jan 23, 2009 | 12:04 PM
divingindaytona's Avatar
Remember stock is BAD!
Charge the battery, this should remedy this problem.
Old Jan 24, 2009 | 09:08 AM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
Charge it or change it, whichever it needs. Mine did that. Changed the battery and the problem went away. Battery had several years on it.
Old Jan 24, 2009 | 09:25 PM
ericb269's Avatar
kneeedragger
i am probly going to sound stupid but is there a battery in the instrement cluster because my bikes bttery is new and the bike cranks fine any more ideas
Old Jan 25, 2009 | 02:09 AM
No... There are no battery in the gauge...
Did you check the fuses?
Old Jan 25, 2009 | 02:28 AM
RK1's Avatar
RK1
Don't know if it's the cause here but one of the symptoms of a failing regulator/rectifier is that the trip meter resets at engine start up.
Old Jan 25, 2009 | 03:27 AM
Yep... and it's also a cause of blown fuses if it's overcharging the battery and pumping out too high voltage... So I'd start with the simple answears... And then move on to the R/R...
Old Jan 25, 2009 | 10:24 AM
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
Don't suppose you've had an alarm/immobliser recently fitted?
Chris.
Old Jan 26, 2009 | 06:54 AM
ericb269's Avatar
kneeedragger
thanks for all the help guys it was a blown fuse due to a small tear in the power wire but it is all good now. thx for everything.
Old Jan 26, 2009 | 12:03 PM
Ok...
And since that blew the fuse I'd check the R/R and stator voltages to make damned sure that all else is within specs if it was my bike... but that's just a tip... electrical gremlins suck bigtime...
mattvdsande
Mar 16, 2009 11:12 AM
wardo996
Mar 26, 2007 09:39 PM
wardo996
Mar 21, 2007 10:20 AM
cliby
Mar 18, 2007 11:50 AM
mr.billet
Nov 4, 2006 08:28 PM
