Gas line
Old Jun 3, 2020 | 01:25 PM
Kevin Schmidt's Avatar
Kevin Schmidt is on a distinguished road
Gas line
Where does this line go to that's in between the carbs
Old Jun 3, 2020 | 01:40 PM
Cadbury64's Avatar
VTR virgin
Those are carb air vent tubes, they are meant to be just where they are.
Old Jun 3, 2020 | 01:44 PM
Thats what i thought but the one on the left when I try to start the bike it leaks so thats why im asking. Any help would be much appreciated
Old Jun 3, 2020 | 02:33 PM
Cadbury64's Avatar
VTR virgin
If fuel is coming out from the air vent then the carb is over-filling. Fuel flows by gravity from the fuel tank/petcock into the carb by way of the float valve. The float valve floats up and shuts off the fuel when the right level has been achieved in the float bowl, just like the ballcock in a toilet cistern. The overflow you are seeing t means the float needle is not sealing, which could be a worn needle or seat or a bit of debris stuck in the valve. Sometimes tapping the carbs gently will dislodge a bit of crud and help it seal, but its probably best to remove the carbs and the float bowl for a good inspection/clean out. With the bowl off, you can just slide the float pivot pin out and lift the float and float needle out for a look/clean. The diagram is from the common service manual so you know what I'm on about.
Old Jun 3, 2020 | 02:58 PM
I fixed the leak i was just dumb and switched 2 line in the petcock before this it did not run now it runs for 3 ish mins then dies. So know what do you think cause im just lost now
Old Jun 3, 2020 | 03:12 PM
Cadbury64's Avatar
VTR virgin
The petcock needs vacuum to open it to let fuel flow, so if there's no vacuum you will run the carbs out of fuel. The fitting on the very back of the fuel tap needs to be connected to the vacuum hose that comes from the left side the carbs and connects to one of the intakes. The other fitting is just an overflow vent so the hose (if there is one) should disappear under the engine somewhere.
Check out this post: https://www.superhawkforum.com/forum...ix-pics-19843/
Chris03653837
Mar 27, 2016 07:07 AM
HellsAekel
Feb 7, 2015 11:00 PM
justinity
May 3, 2011 02:49 PM
haknslash
Sep 25, 2008 03:19 AM
Thumper
Sep 22, 2008 09:03 PM
