funky decel...
Old May 15, 2008 | 02:48 AM
  #31
gboezio's Avatar
Set a piece of paper on the throttle screw see if it's tight, maybe the blades are sticking from a bad cable, you probably checked this already but something is causing this other than the stuff you swapped
PS: on a side note, a weird place for an intake leak, but possible is a damaged valve guide and seal some air can be sucked trough the crankcase vents, in this case it should be burning oil.
Old May 15, 2008 | 08:39 AM
  #32
Throttle cables are as new. I checked the valve guides and replaced the valve seals when I rebuilt the heads earlier this year. It doesn't seem to be burning any oil.
Old May 15, 2008 | 10:23 AM
  #33
divingindaytona's Avatar
Remember stock is BAD!
Originally Posted by trinc
hanging idle normally means your running lean.
This is the first thing that comes to mind. If you are not running lean it is possible that you have an air leak.
SuperCleat
Jun 25, 2010 12:39 PM
ViperBoy
Jun 20, 2008 08:43 AM
DBERN
Sep 23, 2006 09:11 PM
collectiv
Apr 21, 2006 08:24 PM
EngineNoO9
Nov 22, 2005 08:37 PM
