so umm... I'm not getting popping anymore on decel...
Old Nov 21, 2005 | 10:47 AM
EngineNoO9's Avatar
stupid yes but I'm wondering why... Maybe from running 93 the last two tanks instead of 91 like normal?? i have full exhaust and stage 3 jet kit... any ideas???
Old Nov 21, 2005 | 11:12 AM
marmaladedad's Avatar
Hmm?
PAIR valve removed/blocked?
Old Nov 21, 2005 | 12:10 PM
EngineNoO9's Avatar
nope. that's stock
Old Nov 21, 2005 | 12:23 PM
NOrrTH's Avatar
Re: so umm... I'm not getting popping anymore on decel...
Cold air?
Old Nov 21, 2005 | 12:35 PM
EngineNoO9's Avatar
yeah it was cold out. I was wondering if that maybe had an affect. I was just nervous cause normally it does and was hoping nothing was wrong with it...
Old Nov 21, 2005 | 06:45 PM
Randman's Avatar
Moderate-whore
I know that popping....It was cold out here yesterday, on a 75 mile loop, she popped the whole ride....I use 93 gas, so did the previous owner...Wonder if there is anything that can be done to get rid of it??
Old Nov 21, 2005 | 07:38 PM
EngineNoO9's Avatar
that's just the opposite of mine. it was cold like low to mid 40's and she didn't pop at all. I love the popping on decel. heh. I'll try 91 next time to see if there's a diff
Old Nov 21, 2005 | 07:53 PM
superhawk22's Avatar
Believe it or not it actually runs better on 87 or 89 octane unless you've done engine work to it. I know I didn't think so either until I read it here and tried it out. Low compression engine is the reason.
Old Nov 22, 2005 | 05:40 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
does higher octane gas really make a difference? i would like to use the 87 because its cheaper but will it hurt my engines performance?
Old Nov 22, 2005 | 07:18 PM
EngineNoO9's Avatar
no. 87 or 89 really is best since it's low compression. It won't hurt to throw in higher but it'll actually run better on the lower octane. In case you're unaware, lower octane has more energy then higher octane. Higher octane is designed for high compression motors so it won't combust due to the compression stroke of the motor causing early detonation messing up the motor. Lower octane would detonate from the compression before the spark hits it. We don't have high compression motors and unless you've done engine work with cams and raising the compression any there's no need to run higher. I actually am not liking the way my bike is running on 93. 91 seemed to run real well. Haven't tried 89 or 87....
Old Nov 22, 2005 | 08:34 PM
SillyHawk's Avatar
so most people either arent aware of this or think it does in fact improve performance? so i am OK running 87 and paying the $2.45 out here in Los Angeles...sweet. i will try it out next tank and see if i feel any difference.
Old Nov 22, 2005 | 08:37 PM
EngineNoO9's Avatar
for the stock motor I'd probably personally run mid grade... Though I'd almost just say try each grade and ride whichever feels best. Only way I'd bump up the grade is if you hear pinging of the engine (it'll sound like pings... don't know how else to describe it) Though I doubt it'll do that on a stock motor... I have a little carb work and full exhaust so I feel a little more comfortable running 91. I'm gonna try mid and low grade in the spring though... (putting my bike up for winter soon)
jonjonsocal
Oct 26, 2014 11:29 PM
andy9743
Oct 17, 2007 04:00 AM
DBERN
Sep 23, 2006 09:11 PM
seattlesucks
Sep 9, 2006 09:15 AM
collectiv
Apr 21, 2006 08:24 PM
