Full throttle hesitation
Old Jul 22, 2010 | 10:31 AM
Stevebis1's Avatar
Bike sat for ~2-1/2 weeks, ran fine before but now is very rough (feels like a cylinder cutting out) at full throttle from 4200rpm all the way to redline. If I back off to 3/4 throttle or less problem seems to go away. Idle and part throttle running is fine.
There were no changes to the bike, just the down time. Bike is dynojetted - don't know settings, set up by PO, OEM filter, micron slip ons, depaired with block off plates. Plugs have been in for 1 year maybe 5000 miles.
I put in 1/2 can of seafoam and have ridden it about 100 miles in this condition. Does not seem to be improving at all.
I'm guessing I'll have to pull the carbs this weekend - this will be my first time on the SHawk and I'm a bit nervous. My only carb experience in on the Mikunis on my boat and jet skis. I'm thinking that one of the main jets might be clogged. I'm not looking to change anything at this point (needle clip, etc) as the tune was great previously, just need to fix whatever changed.
Am I on the right track? Should I try something else?
Old Jul 22, 2010 | 11:31 AM
Well it is pretty hard to clog up a main jet on these bikes as they are rather large. You might want to try draining the tank and filling it with fresh fuel first to see if that makes any difference before you pull the carbs.
Old Jul 22, 2010 | 12:25 PM
Stevebis1's Avatar
Today and tommorow back and forth to work will take care of the gas - 45 miles each way. I could pick up another set of plugs and install them pretty quickly too.
This is annoying as I just picked up a +4 advancer and Dr Honda delivered my billet intakes. Can't make any changes till I get her back to where she was...
Old Jul 29, 2010 | 09:18 AM
Stevebis1's Avatar
Okay, since I screwed up the water pump I never finished this thread. Attached is the reason for the hesitation...
damn mice had made a nest over the filter.
Needless to say it ran just fine after I cleaned the crap out.
Attached Thumbnails Full throttle hesitation-img00147-20100725-1125-small-.jpg
Old Jul 29, 2010 | 09:58 AM
nothing's Avatar
ride it out
lol I'm at a loss of words
Old Jul 29, 2010 | 09:59 AM
Yeah that might affect the air flow just a little bit.....
Old Jul 29, 2010 | 11:54 AM
ranchomice's Avatar
Wow, that mickey mouse comment a while back was not as much of a joke as it appeared!
VTArrrgh!
Oct 21, 2013 01:45 PM
ranchomice
Jun 12, 2010 07:06 AM
ranchomice
Jun 10, 2010 04:01 PM
cal2az
Sep 18, 2008 07:13 PM
DocPigskin17
Jun 20, 2007 04:09 AM
