Fuel Valve
Old Nov 13, 2008 | 05:29 PM
Starbucks Fueled's Avatar
Starbucks Fueled is on a distinguished road
Fuel Valve
Now that I finally got the damn thing running again, there is fuel dripping from the weep hole on the fuel valve. I'm assuming the diaphram has a hole or crack in it, as it sat for 2 years. Just looking for any advice before I tear it apart. Is it the diaphram, or can it be something else I'm missing. TIA.
Old Nov 13, 2008 | 08:52 PM
dakmatik's Avatar
dakmatik is on a distinguished road
sounds like a bad diaphram in the petcock like you said. I had the same problem on mine last summer. Not a hard fix, luckily.
Old Nov 13, 2008 | 08:54 PM
Diaphragm is toast. you can by pass it and have the fuel on at all times, but the needle and seats in the carbs better be in good condition or else the carbs will over flow.
Old Nov 13, 2008 | 09:34 PM
Honda sells the rebuild kit for like $25. Look it up on Ronayers.com parts fiche.
Old Nov 14, 2008 | 01:20 PM
Thanks Hawkrider, I'll check it out and get one on the way. Thanks all.
residentg
Jun 17, 2021 04:37 PM
Fox
Dec 14, 2010 11:46 AM
superman_006
Jul 24, 2010 10:17 PM
avramd
Oct 22, 2009 08:42 AM
seb421
Feb 4, 2009 05:49 AM
