frozen coolant system
Old Dec 18, 2010 | 06:23 AM
20_rc51_00's Avatar
long story short.... new bike to me, thought there was coolant in system....wasn't..... system frozen.... what is the best way to go about this?.... fawk
Old Dec 18, 2010 | 06:55 AM
Bring it indoors and let it thaw.... and hope that nothing broke (like the engine block)
Old Dec 18, 2010 | 06:56 AM
20_rc51_00's Avatar
I don't see any leaks or icicles from the negine block but I can't see into it so that is tbd
bringing it inside is not an option unfortunately...
Old Dec 18, 2010 | 07:01 AM
cliby's Avatar
i think it will be hard to tell. depends on how long and how much fluid, what type etc. Bring it in to thaw for sure. The biggest worry will be cracks in the circuit around the engine and you won't know that for sure until/if you see contamination (milky) in the oil after running for awhile. Once warmed be sure to change the radiator fluid obviously also. good luck
Old Dec 18, 2010 | 07:02 AM
cliby's Avatar
sorry, just saw you can't bring it inside. is it in a cover storage you can get a heater into for awhile? Otherwise find a friend with heated garage.
Old Dec 18, 2010 | 07:30 AM
tbartley's Avatar
Get it thawed ASAP! Inside someone's garage, basement, van, truck, under a tarp with a heater, etc. Get it up the stairs and into the apartment...into the back of the closest Walmart store or any store for that matter...somewhere brother.
If it keeps getting colder wherever you are and the ice still has room to expand...it will! Then you will be parting out your bike on this website!
Old Dec 18, 2010 | 04:01 PM
Agreed... Thaw it, ASAP...
Old Dec 18, 2010 | 05:50 PM
The last motor I saw that froze was a RC-51 and it cracked both heads....
Old Dec 18, 2010 | 09:45 PM
Meierznutz's Avatar
Meierznutz is on a distinguished road
Get some antifreeze into it asap. Even a little bit will start to thaw the coolant. Keep adding as the water starts to slurry. As it seeps through the system you should be able to drop off a lower hose and then replace it once the liquid drains. Add more AF and the mix will get to a point where it will thaw the rest. Once you have done this a couple times you should be able to see that the ice crystals have been absorbed. Once you are sure there is no ice in the water pump you can start her and see where she's leaking. If you do this soon enough you might have gotten lucky.
Old Dec 18, 2010 | 11:24 PM
20_rc51_00's Avatar
the temps have been only a few deg C below freezing, it wiill freeze water but my hope is that it froze the water at a rate slow enough that the expansion could have take place and displaced the liquid water where it could as it was freexing...... anyways...
I unscrewed the water pump cover and removed all ice that would be blocking it. then left it open for a while and with the bike idling let whatever water could pour out. I am guessing there was about a liter of water that was thawed then I buttoned it back up and by the the heat of the bike was enought htat most of the rad tubes etc had slush in them that I could squish by hand. I then proceeded to pour coolant into the rad while it was running for a little while. my hope is that nothing internally was damaged, I guess time will tell. I hope that the rads are fine and that there is not leakage from them either. this was the best that I could do with what I have available to me, I do not have a garage, I do not know anyone with a garage etc etc. i figured it was the best option that I had, ie to salvage the water pump..... anyways, time will tell.... wish me luck
Old Dec 18, 2010 | 11:34 PM
You could actually run a garden hose on it to thaw it, although if you dont have access to a garage then a hose may be a long shot. I would be hopeful if the temps werent much below freezing. Even buckets of warm water dumped on it could do the job. I work on my bike on the sidewalks here in NYC & could at least do the bucket thing so get it defrosted and drained at least. If its dry it at least wont break. My bet is that you are not totally screwed.
Old Dec 19, 2010 | 05:42 AM
ttocsmai's Avatar
if you can keep it dry outside, throw an electric blanket around it with the heat up all the way. give it a day or so then look at it.
Of course, if it is 0 degrees outside the blanket will not do a thing unless you insulate it somehow.
Old Dec 25, 2010 | 04:49 PM
tbartley's Avatar
OK...good luck! Keep us posted, eh?
Old Dec 26, 2010 | 07:46 AM
Meierznutz's Avatar
From experience I can tell you that adding antifreeze will do more and quicker.
Tebs
Jul 8, 2013 01:11 AM
20_rc51_00
Jun 16, 2012 09:54 PM
Fozzy Bear
Aug 8, 2010 02:25 AM
j_frank
Apr 28, 2007 11:40 PM
faz
Jul 29, 2004 10:58 AM
