Front turn signals
Old 06-09-2014, 12:50 AM
NZSpokes's Avatar
Front turn signals
My Hawk is the only one I know of in NZ. Here they are called Firestorms and have a different system for the front turn signals. Mine has the signals on all the time and they blink when I indicate. Can LEDs be made to do this? All the ones for sale here are 2 wire ones and my bike has 3 wires.
Any Ideas?
NZSpokes is offline
Old 06-09-2014, 01:26 AM
NZSpokes's Avatar
Ignore me, found it.
Convert 2 wire signals to 3 Wire Inputs - CBR Forum - Enthusiast forums for Honda CBR Owners
NZSpokes is offline
Old 06-09-2014, 05:24 AM
tbartley's Avatar
Wow, NZSpokes...pretty cool having one of a kind.
tbartley is offline
Old 06-09-2014, 05:47 PM
RobertLever's Avatar
The Proton LED turn signals can be programmed to be running lights as well as blinkers
RobertLever is offline
Old 06-10-2014, 10:08 PM
Deals Gap is a Hoot!
SIRR1's Avatar
SIRR1 is on a distinguished road
All 4 of my turn signals are on all the time, there called running lights...
My front 2 are OEM bulb type and the rears are gone, I am using a integrated under seat panel that has LED running, turn and brake lights in one unit.
In order to use LED running lights as turn signals you will need a Resistor that connects to the positive and negative leads to each blinker.
Here is an example on ebay.
2 Two LED Load Resistors 50W 6ohm Bulb Fix Fast Blinker Blink Turn Signal Flash | eBay
I have wired up bunch if you have any problem give me a shout.
SIRR1
SIRR1 is offline
Robin427
03-16-2012 02:50 PM
Robin427
03-16-2012 01:18 AM
johnclopp85
05-13-2009 07:20 AM
snowman666
04-17-2007 06:58 AM
Quick Reply: Front turn signals
