Front turn signals
Front turn signals
My Hawk is the only one I know of in NZ. Here they are called Firestorms and have a different system for the front turn signals. Mine has the signals on all the time and they blink when I indicate. Can LEDs be made to do this? All the ones for sale here are 2 wire ones and my bike has 3 wires.
Any Ideas?
Any Ideas?
All 4 of my turn signals are on all the time, there called running lights...
My front 2 are OEM bulb type and the rears are gone, I am using a integrated under seat panel that has LED running, turn and brake lights in one unit.
In order to use LED running lights as turn signals you will need a Resistor that connects to the positive and negative leads to each blinker.
Here is an example on ebay.
2 Two LED Load Resistors 50W 6ohm Bulb Fix Fast Blinker Blink Turn Signal Flash | eBay
I have wired up bunch if you have any problem give me a shout.
SIRR1
SIRR1
Magnus
May 29, 2014 06:52 PM
johnclopp85
May 13, 2009 07:20 AM
