Front Fork Seals
Old Aug 12, 2008 | 01:30 PM
Starbucks Fueled's Avatar
Starbucks Fueled is on a distinguished road
Front Fork Seals
My 00 Hawk needs fork seals. Is there anything out there anyone can recommend that is better than stockers? TIA
Old Aug 12, 2008 | 01:49 PM
filter69's Avatar
Thats Mr Dill hole to you
Yea but there attached to a 4 grand set of ohlins forks
My left one's started to leak so im gonna send them to greg this fall and and have him od his susp. guru **** to em srp[ings.valve rework seals the works i can't wait....
Old Aug 12, 2008 | 03:12 PM
FTMS's Avatar
OEM are about the best. I have had good luck with K&L brand seal also. Stay a way from Leak Prof brand seals. All they do is leak. There is not a lot of choices for fork seals.
Old Aug 12, 2008 | 05:24 PM
JamieDaugherty's Avatar
Don't use anything besides Honda seals... unless you like to change them every year or so. I only install Honda seals on the forks I rebuild now, anything else is sub-par to say the least.
Old Aug 13, 2008 | 07:44 AM
motojoe's Avatar
Sexual Daredevil
Old mechanics trick;
prior to installing new seal, tighten the spring on the seal.
This can be done by popping the spring off the lip.
Find the place where the spring it threaded together.
Hold the spring and twist it as if you were making the spring smaller in diameter.
Threading it into itself a little more.
One or two turns is enough.
This justs add a little more tention to the seal.
This could also be used in a bind if your current seal is leaking. Not a fix, but a band-aid at best.
Old Aug 13, 2008 | 10:09 AM
Thanks for the input guys. I'll stay with the stockers for now.
Old Aug 14, 2008 | 08:40 PM
motojoe, I believe the OEM seals use a spring that has the ends hooking together, not "threading" into each other.
revhead1957
Dec 5, 2010 09:13 PM
cscrawford
Oct 3, 2008 09:51 AM
98honda
Jan 1, 2008 06:30 PM
kshuart
Feb 14, 2007 10:46 AM
nfbzike
Apr 17, 2006 06:42 PM
