fork seals?
Old Dec 21, 2007 | 03:43 AM
98honda's Avatar
98honda is on a distinguished road
fork seals?
were can i find info on front fork seals? my left one started leaking, and i need to buy new set for both and do the work. is it hard to do yourself?
Old Dec 21, 2007 | 06:19 AM
redman's Avatar
www.ronayers.com
You have to take the forks apart, obviously....it's a bit of a pain but doesn't require any special tools. You'll need new fluid too, and if your bike has more than 15-20k miles on it, you may as well get new bushings too...they're cheap.
Old Dec 21, 2007 | 10:49 AM
98honda's Avatar
ok cool, thanks
Old Dec 21, 2007 | 03:56 PM
comedo's Avatar
Good advice on checking the bushings. The part that's the most fun is getting the allen head bolt out of the bottom of the fork. Make sure the forks are drained completely before pulling them apart. Wear old clothes. Buy a manual. Brush your teeth twice a day.
Old Dec 22, 2007 | 05:16 AM
98honda's Avatar
lol,
sometimes when i hit my front brakes i hear a little pop, could that be bushings in the front?
Old Dec 22, 2007 | 05:47 AM
Worn bushings, dirty or contaminated oil, other damage.
If the fluid is old, coupled with leaking seals. You’ll likely to solve the “pop” once the forks have been serviced.
There are a few specialty tools that make the job easier, and one I would not do with out.. The seal driver. Others will advise you can install a new seal with out a driver.. and it can be done. I just prefer the right tool to do the job efficiently with out risk of damaging the seal, waste of time, ect ect. Have a look at Race Tech for parts and tools, or Motion Pro as an alternative source for suspension tools.
If you have not worked on suspension prior, a manual or at least a video on this type of fork really is needed. It’s not hard work, but experience or a manual helps with time and foul up free job.
Old Dec 23, 2007 | 07:31 AM
redman's Avatar
That "pop" could also be loose or worn steering head bearings.
Old Dec 26, 2007 | 10:44 AM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
I made a DIY fork seal driver out of a piece of flanged PVC with an inner diameter slightly larger than than the fork tube. I took my time and it worked fine for me.
Old Jan 1, 2008 | 04:44 PM
Babelfish's Avatar
Babelfish is on a distinguished road
I use the old seals as protection when driving in the new ones. Then the drlf made driver's diametre is not that important.
Old Jan 1, 2008 | 06:30 PM
redman's Avatar
98honda....did you ever get all your parts? It just dawned on me that I bought all new seals an bushings RIGHT before I crashed and subsequently did the frontend swap. I'll send them all to you cheap if you like.
revhead1957
Dec 5, 2010 09:13 PM
cscrawford
Oct 3, 2008 09:51 AM
Starbucks Fueled
Aug 14, 2008 08:40 PM
kshuart
Feb 14, 2007 10:46 AM
nfbzike
Apr 17, 2006 06:42 PM
