Front brake conversion problem.
Old Apr 5, 2008 | 06:34 PM
happytrack44's Avatar
WERA #44
2002 Superhawk meets 2001 GSXR 1000 calipers and master cylinder.
Calipers bolt directly on with new Kevlar composite pads, No problem.
Pair of braided lines from OEM Hawk brakes, And Gsxr Master Cylinder,
bleed and ready.
Bike waits in shed for nice weather to bed brakes and try out.
Roll bike out with big grin on pretty day! Why so hard to push? Brake lever has no play and appears to be holding pressure on the system?!?!?
8mm to blead port while static (no pull on lever)---spurt--
pump and bleed, all checks OK. Put bike up 'cause don't know how long it will ride before binding.
2 days later, same pressure issue.
Master cylinder got full rebuild with a kit before installation, Ebay item, unknown history, I rebuilt it.
I have dealt with this issue before on a hydraulic GSXR clutch, But have any of you seen this and what causes it?
Old Apr 5, 2008 | 06:54 PM
superbling's Avatar
Calipers aren't centered on the rotors. Look again. The inside pistons are probably pushed all the way in now and can't move (stiff lever feel). You'll need to shim the calipers away from the fork mounts with a couple of thin washers to give the inside pistons some "free play" room. I used stainless steel ones from the local home hardware store.
Hope this makes sense.
Old Apr 5, 2008 | 07:01 PM
WERA #44
Indeed, I'll look at that. Thanks!
Old Apr 5, 2008 | 08:05 PM
yellowstorm's Avatar
dave
yellowstorm is on a distinguished road
check for rust on piston in calipers could be stuck keeps brake pad stuck on. & bleed back hole in m/c as well to let pressure release.
Old Apr 5, 2008 | 08:32 PM
Thumper's Avatar
Humm, I didn't have to shim the same calipers on my 98.
Old Apr 6, 2008 | 02:26 AM
What condition are the pistons and seals in?
Old Apr 6, 2008 | 10:40 AM
WERA #44
Pistons and seals looked good on the calipers, nice movement, no complaints when not pressurized.
The system just seems to build pressure when static for a day or two.
When my GSXR clutch did this, a rebuild of the master cylinder cured it.
I just wonder what specifically does this.
Got a 954 master cylinder on the way, maybe the Honda is just rejecting the Suzuki part. But I'm keeping the 6 pots cause they are it.
Old Apr 7, 2008 | 04:44 PM
So, the pressure is just building up inside the brake system?? It's spring so it's obviously getting warmer. The expansion of the fluid would explain this phenomenon, but only with another problem. That problem would be that the master cylinder is not venting to the reservoir correctly. There is a tiny hole between the master cylinder piston and where the tube goes to the reservoir. If that's clogged on the inside then it won't vent. Also, if the piston doesn't return all the way to it's normal free position then it won't vent. Being as it is a Gixxer m/c, check the lever clearances and ensure everything moves as it should.
Old Apr 7, 2008 | 04:50 PM
Thumper's Avatar
Hawkrider is correct, make sure the lever is able to travel all the way to the grip and not hit the Stock VTR throttle housing. I have the same calipers with a 06 GSXR 1000 Radial Master Cylinder and i had to move some things around to prevent the lever from hitting my throttle assembly.
Old Apr 7, 2008 | 05:13 PM
drew_c14's Avatar
+1
I have the same M/C you do, a little tricky to mount. Did you have to cut or grind any on the M/C?
Old Apr 7, 2008 | 06:43 PM
Thumper's Avatar
Yes, but i also had to rotate the throttle assembly a little as well to keep the lever from hitting the throttle cable housing. This will require you drilling a new throttle postion hole in the clip-on to allow the housing located pin to be moved forward. Notice I run my lever much further down than the stock position. I like to be able to pull my fingers off the grip and as they move forward they just clear the top of the lever.
As well make sure the part of the lever closest to the triple tree mount (nearest center of bike) isn't hitting the brake lines.
Don't know if these will help or not, but here are a few pics of my completed setupName:  GSXR1000MC051.jpg
Old Apr 8, 2008 | 02:36 AM
WERA #44
I notice the lever doesn't return to rest position all the way, you can push it out a small amount after it returns. I guess something is wrong inside. Time to pull it down.
Old Apr 8, 2008 | 06:26 AM
superbling's Avatar
It's been too long since I had them on the stock forks. I know I had to shim them when I moved them over to F4i forks which uses different axle spacers, etc., so that's probably what I'm thinking about. Sorry for the confusion.
Happy,
Sounds like a stuck piston or two or three or........
Old Apr 8, 2008 | 07:07 PM
Thumper, what kind of fluid is that? Is that just the pic, cuz it looks almost pink/orange. I thought Dexcool when I saw it! Ha!
Old Apr 8, 2008 | 08:00 PM
Thumper's Avatar
Nice catch Hawkrider! I was wondering from my previous post why no one had noticed the strange color.
I did an Ed Bargy Racing school a few years ago and as part of the school you got a race package of goodies valued at about a third of the Race class. The race package included all kinds of Motul race lubricants and the RBF600 brake fliud you see was included. I have since used the free bottle and bought more and installed on my other rides.
I am no lubricant expert, so free is free and if it works, i'll buy more as i did.
Here is a link to the product detail on Motospotstore.com site. Stuff is not cheap, which i guess means it is GOOD.......lol
Along with Vesrah pads you have a great combo...
Oh the color you see is the actual color. Kind of unusual......
http://www.motorspotstore.com/rbf600radot4.html
How could you go wrong with this logo.......
Old Apr 8, 2008 | 08:16 PM
Loco's Avatar
Loco
That sounds like there isn't enough pressure in the system to begin with, probably due to air in the system?
Isn't the simplest solution supposed to be the correct one. Maybe the right answer here isn't in the brake system at all, it could be a bad lever.
Usually, if something is sticking, or not returning to its original state, the pressure either wasn't correct to begin with, or it's being dissipated in an unwanted location, anywhere from the bleed valve at the bottom to a seal at the top of the lever.
Old Apr 24, 2008 | 05:27 AM
WERA #44
Problem solved, 954 master cylinder installed, fit like a honda part, not much trouble.
Bled to perfection in about 10 minuets
Works very well with the GSXR 6 pots.
The GSXR master cylinder has some issues. Greg was right about the non-venting issue.
Old Apr 24, 2008 | 06:22 AM
Thumper's Avatar
Humm, my 06 GSXR Radial Master cylinder vented easier than the crappy stock OEM Honda Master Cylinder
Old Apr 24, 2008 | 04:06 PM
Could be the PO used silicone DOT 5 and it swelled the seals, then couldn't figure out what went wrong and sold it to to an unsuspecting buyer (no offense) on ebay.
bostonhawk
Sep 1, 2012 08:45 AM
ff
Mar 27, 2008 09:20 AM
DocPigskin17
Jul 16, 2007 09:55 AM
Flight_996
May 28, 2007 08:55 PM
cb21983
Jun 19, 2006 11:30 AM
