Fork Removal
Old Nov 6, 2014 | 04:59 AM
mikenap's Avatar
mikenap is on a distinguished road
Fork Removal
I don't have a triple tree stand (only reg front fork stand).
Thinking I can just put a block of something or jackstand under the engine? Looking for idea's or some pictures. Bike will have to stay this way while the forks are being rebuilt ....want it to be secure/stable.
Old Nov 6, 2014 | 05:04 AM
You can support it from below as you outline, but IMO that's not very stable with this bike. Add some straps and hang it from the rafters for stability.
Old Nov 6, 2014 | 07:08 AM
twist's Avatar
When I installed a new shock, I supported the bike from an A frame ladder, one of the type that is made so it can be straight or pivot and lock at the center. They can hold the bike no problem.
Old Nov 6, 2014 | 10:04 AM
HawkRider98's Avatar
Yea i did the board and floor jackstand when I replaced my rear shock. Ended up replacing my tank also. It's the coming down part you got to worry about. Just make sure you have someone on both sides of bike on way down.
Old Nov 6, 2014 | 12:00 PM
Yup. I use a soft piece of pine on my floor jack @ the oil pan, rear being held by a stand. It's a little shakey but you should be fine, just be careful.
Old Nov 6, 2014 | 01:10 PM
If you're looking for a bit of added security.
Rear on a stand, 24x24 or larger piece of 3/4 plywood with two eye bolts at the edges.. place the plywood under the bike, roll the floor jack on top of the plywood use a small piece of wood on the jack pad,, Lift the bike under the motor at the oil pan..Then use two straps from bike to eye bolts in plywood to stabilize the bike
Old Nov 6, 2014 | 04:49 PM
get a stand. You can get them for forty something clams on fleabay. If you do the mickey mouse thing and tip the bike you will spend way more than that on parts in damage, not to mention if it lands on you (it will).
It is beyond worth having since you own a bike and you can sell it for what you paid when your done. (I had one 3 yrs and got my money back).
inderocker
Jun 7, 2010 12:22 AM
AngryOlaf
May 25, 2010 09:39 AM
HawkRider98
Sep 10, 2008 09:07 AM
mikstr
May 3, 2007 05:38 PM
Streaky
May 2, 2007 08:06 AM
