Fork oil change HELP!!!!
Old May 11, 2013 | 04:34 PM
Euro.matt's Avatar
Euro.matt is on a distinguished road
Here is my problem. I am currently putting new fork seals and oil in my spare forks in order to hopefully get my current set i am riding on re-valved by Daugherty Motorsports this summer. Any ways I have them all back together and when pushing down on them they seem to be very stiff. I think i messed up when setting the oil level. I set it at 130mm from the top of the fork tube but I had the fork fully extended. I am now reading the service manual and it was saying to set level with them full compressed. So what I am asking is did i Eff up and put to much oil in the fork? Should i remove the spring and compress the fork the reset the level?
Old May 11, 2013 | 04:37 PM
RWhisen's Avatar
Former Superchicken Owner
Yes you should.
Old May 11, 2013 | 04:45 PM
Spring out, stanchion compressed. Oil level is measured to the top of the stanchion.
Old May 11, 2013 | 05:05 PM
Euro.matt's Avatar
Ok thank you for the quick replies. I was reading the book after I finished ( friend helped with rebuild ) and remembered we set the oil level with the fork extended and was second guessing our work.
Old May 11, 2013 | 07:00 PM
Caffeine's Avatar
Caffeine is on a distinguished road
I used 130mm from the top.. springs in, forks fully extended.. worked fine!
7.5wt oil
Old May 11, 2013 | 07:28 PM
RWhisen's Avatar
7.5wt oil
So you really have no idea what your forks are set up for. What kind of spring did you use? Did you change valving? What is your sag, static and loaded?
Old May 11, 2013 | 07:59 PM
Whats with all the newbies flagrantly abusing exclamation points???????????!!!!!!!!!!!!!!!!
Take it easy guys, save it for a real emergency, like a roadside breakdown or something.
Old May 12, 2013 | 04:58 AM
7.5wt oil
I jumped out of an airplane once without a working reserve... , main worked fully, so it "worked fine".. still was a stupid move and not right.
I see a parallel
Old May 12, 2013 | 07:48 AM
Marquez great analogy.
I always tell people that you can cross a busy street blindfolded and make it. But that doesnt make it right or even prudent.
Old May 12, 2013 | 11:51 AM
Oh and for fork oil level, its best to use one of these tools
http://www.motorcycle-superstore.com/14/71/995/4844/ITEM/Motion-Pro-Fork-Oil-Level-Tool.aspx?SiteID=Google_PLA995&WT.mc_ID=10012&esvt =0-GOUSC&esvadt=9-0-3886819-1&esvaid=30548&kw={keyword}&gclid=COro__idkbcCFUJx 4AodNg4AMQ
But you can improvise with a dollar store turkey baster.
Old May 12, 2013 | 12:14 PM
HRCA#1's Avatar
+1 on the old turkey baster but you got hosed, 89 cents on an after thanksgiving clearance rack..lol. I've been using one for years!
Old May 12, 2013 | 12:32 PM
HRCA, Can I borrow it? I will give it right back.........
Old May 12, 2013 | 04:27 PM
zxbud's Avatar
Borrow It?
Nah, you should find one in the wifey's kitchen drawer. If you're discreet she'll never know.
Old May 13, 2013 | 09:40 AM
JamieDaugherty's Avatar
In case it helps:
Daugherty Motorsports - V4 Honda Carb Removal and Installation Procedure
Old May 13, 2013 | 04:32 PM
twist's Avatar
I tried that once, don't do it! They always know and the consequences are not pretty! Don't use the oven to heat parts for bearings either. Their noses can detect oil at 100 parts per billion.
Old May 13, 2013 | 06:37 PM
HRCA#1's Avatar
Trust me Twist is right, not only for the baster but the time I cured the fork leg coating in the oven, well let's just say it wasn't the best 2 weeks of my life!
Old May 14, 2013 | 07:17 AM
2 weeks? Your wifey is mellow... Last time I used any kitchen utensils for non-sanctioned activities I got the cold shoulder for a lot longer... The upside was that I got out of cooking duty for about a month, until I was allowed entry again...
Old May 14, 2013 | 07:34 AM
All this reminds me of a t-shirt I saw that pretty much can explain ALL dealings with women. (I know that seems impossible)
It simply read "Bitches be trippin'"
It has yet to steer me wrong. No matter what happens, this explains all. Any girl troubles anyone brings to you, refer to the t-shirt wisdom.
Old May 16, 2013 | 03:52 PM
Euro.matt's Avatar
HRCA you read my mind. I went to the dollar store and bought a turkey baster used some vacuum line and a piece of metal brake line laying around to make my level tool. Jamie that as very help full i was not aware you had that info on your site. Now if only I can get over this cold i am good to go riding on sunday.
Old May 19, 2013 | 06:17 PM
Yeah, whats with this year? I have broncitis. Put a damper on my race weekend.
Old May 20, 2013 | 04:15 PM
Euro.matt's Avatar
I defiantly felt alot better. Was a great day in pa. only down side was booger falls going on from my nose....
correll1000
Sep 18, 2011 08:52 PM
AngryOlaf
May 25, 2010 09:39 AM
Sherm831
May 18, 2010 07:07 PM
Randman
Mar 30, 2007 05:38 AM
NOrrTH
Nov 25, 2005 09:59 AM
