Fork oil change HELP!!!!
Here is my problem. I am currently putting new fork seals and oil in my spare forks in order to hopefully get my current set i am riding on re-valved by Daugherty Motorsports this summer. Any ways I have them all back together and when pushing down on them they seem to be very stiff. I think i messed up when setting the oil level. I set it at 130mm from the top of the fork tube but I had the fork fully extended. I am now reading the service manual and it was saying to set level with them full compressed. So what I am asking is did i Eff up and put to much oil in the fork? Should i remove the spring and compress the fork the reset the level?
Yes you should.
Originally Posted by Euro.matt
(Post 354704)
Ok thank you for the quick replies. I was reading the book after I finished ( friend helped with rebuild ) and remembered we set the oil level with the fork extended and was second guessing our work.
I used 130mm from the top.. springs in, forks fully extended.. worked fine!
7.5wt oil |
Originally Posted by Caffeine
(Post 354731)
7.5wt oil |
Whats with all the newbies flagrantly abusing exclamation points???????????!!!!!!!!!!!!!!!!
Take it easy guys, save it for a real emergency, like a roadside breakdown or something. |
(Post 354731)
7.5wt oil I see a parallel :rolleyes: |
Marquez great analogy.
I always tell people that you can cross a busy street blindfolded and make it. But that doesnt make it right or even prudent. |
Oh and for fork oil level, its best to use one of these tools
http://www.motorcycle-superstore.com/14/71/995/4844/ITEM/Motion-Pro-Fork-Oil-Level-Tool.aspx?SiteID=Google_PLA995&WT.mc_ID=10012&esvt =0-GOUSC&esvadt=9-0-3886819-1&esvaid=30548&kw={keyword}&gclid=COro__idkbcCFUJx 4AodNg4AMQ But you can improvise with a dollar store turkey baster. |
+1 on the old turkey baster but you got hosed, 89 cents on an after thanksgiving clearance rack..lol. I've been using one for years!
HRCA, Can I borrow it? I will give it right back.........
Borrow It?
(Post 354784)
Nah, you should find one in the wifey's kitchen drawer. If you're discreet she'll never know. :D |
Originally Posted by zxbud
(Post 354814)
Trust me Twist is right, not only for the baster but the time I cured the fork leg coating in the oven, well let's just say it wasn't the best 2 weeks of my life!
2 weeks? Your wifey is mellow... ;) Last time I used any kitchen utensils for non-sanctioned activities I got the cold shoulder for a lot longer... The upside was that I got out of cooking duty for about a month, until I was allowed entry again...
All this reminds me of a t-shirt I saw that pretty much can explain ALL dealings with women. (I know that seems impossible)
It simply read "Bitches be trippin'" It has yet to steer me wrong. No matter what happens, this explains all. Any girl troubles anyone brings to you, refer to the t-shirt wisdom. |
HRCA you read my mind. I went to the dollar store and bought a turkey baster used some vacuum line and a piece of metal brake line laying around to make my level tool. Jamie that as very help full i was not aware you had that info on your site. Now if only I can get over this cold i am good to go riding on sunday.
Yeah, whats with this year? I have broncitis. Put a damper on my race weekend.
I defiantly felt alot better. Was a great day in pa. only down side was booger falls going on from my nose....
