First Valve Adjustment at 67k miles
Old Dec 29, 2012 | 01:49 PM
Yeah, I know... What took you so long to get around to that?
Well, I finally finished the valve adjustment on my rear cylinder. The Holidays, a cold garage, a 66 year old back, and general procrastination combined to make it a marathon project. Plus, I've had my wife's spare bike to ride, an '07 SV650S, so I wasn't in a big hurry. But I finally got her fired up yesterday.
At 67,285 miles, one intake and both exhaust valves on the rear cylinder were tight. They had some lash, but were out of spec. The other intake was at the low end of the spec. I ordered OEM shims from the dealer to get them all in the middle of the spec range.
I also replaced the rear CCT (I'd replaced the front CCT 3 months ago). I used OEM CCTs.
Now I have to get myself motivated to tackle the front cylinder valve adjustment. My back's really going to like that one. But I'm figuring they probably won't be quite as tight, since the front cylinder should run a little cooler.
I sure miss the 20 minute valve adjustments on my old CX500 and BMW R100RS (both had set screw adjusters). And my CB700SC Nighthawk S had hydraulic adjusters.
Old Dec 29, 2012 | 02:00 PM
VeeTR's Avatar
VeeTR is on a distinguished road
It's a good thing to get in there and get it done,only did mine a while back but the difference since that tune up is night and day,dont forget to sync the carbs when your done
Old Dec 30, 2012 | 11:46 AM
JamieDaugherty's Avatar
Interesting that your exhaust valves were tight, often times they get loose (intakes get tight). I'm not surprised that you've been able to go this long - it's a Honda after all!
superman_006
Jul 24, 2010 10:17 PM
CentralCoaster
May 16, 2009 05:51 AM
viperkillertt
Apr 21, 2009 10:20 AM
dsevans
Jan 1, 2009 01:20 PM
AZZKIKER
Mar 21, 2006 09:43 PM
