A few pics of my fork spring swap
Old Feb 12, 2012 | 06:02 PM
Finished up my Race Tech spring install today. I snapped a few pics in case anyone is searching for info.
First let me say if you haven't changed your fork fluid in the last 5 years, shame on you!! The stuff that's in there is TOAST!!
This is the fluid:
This is what came out after two flushes w/ brake parts cleaner:
And my fluid was just changed 3 seasons ago! So seriously, get that fluid changed!!! Filled the forks w/ new fluid. 130mm gap, fork tubes fully compressed, no springs.
Moving on, cut the spacer yadda yadda.
Mine was 68mm. I haven't put the forks back on to set sag and verify the 68 is perfect soo.
UPDATE: The 68mm allowed me to set sag no problem. I'm at the 2nd line on the preload adjuster.
Putting things back together, I noticed the Race Tech provided washers are too large to get past the threads in my forks. I took several pics:
So I reused the oem ones.
New spring is in, washer on top, fork tube fully compressed.
Add spacer, washer, and "spring seat"
Screw rebound in till notch is flush w/ preload top and dot lines up w/ sticker, then screw cap onto rod:
Gently seat then lightly lock the two together...thighten down cap and viola, I'm done. Like I said, this isn't so much of a how to but a helping hand if someone needs it.
If you have anything to add to this to help out someone in need, please do so. I searched for hours to try and find some pics w/ very little success. I wasn't sure how far down the rod the cap should have been threaded. So hopefully I got everything right.
Old Feb 12, 2012 | 06:29 PM
How far you thread that cap is VERY important. Follow these steps:
  • Loosen the locknut
  • Back the cap off several turns
  • Screw the rebound adjuster in so the dots match and the screw head is flush with the preload adjuster
  • Gently screw the cap back down
  • When you feel resistance the rebound adjuster has seated
  • NOW tighten the locknut, making sure to use your 14mm wrench on the preload adjuster for counter torque
  • Now set your rebound adjuster where you want it
  • Rinse and repeat on the other side
Old Feb 12, 2012 | 07:09 PM
nath981's Avatar
+1............ and you won't find that info in the manual either.
nice pics wolve. Looks like you were close to tastin that nasty ****.
Old Jan 30, 2015 | 07:24 AM
nath, you still alive??
Bearshawk
Oct 3, 2011 04:21 AM
jeephawk
Aug 29, 2011 06:32 AM
Hawkrider
Jun 1, 2009 07:41 PM
Wolverine
Jul 31, 2008 06:30 PM
killer5280
Oct 3, 2006 09:03 AM
