Factory Shift kit Removing case cover
Old Dec 20, 2009 | 08:40 PM
jefejrs's Avatar
jefejrs is on a distinguished road
Hey those in the know,
Putting in a Factory shift kit and cannot get the case cover off. Any tips or tricks I'm missing. Yes all bolts are out and yes I did a quick search..no dice. Thanks in advance.
Old Dec 20, 2009 | 11:19 PM
Over time the gasket has "become one" (so to speak) with both the case and cover. There are pry tabs on the cover to aid in removal. Do not use too much force on those as they can break. Also, do not pry on the mating surfaces of the case and cover.
Old Dec 20, 2009 | 11:29 PM
Here is a nice write up on a Factory Pro detent arm install.
https://www.superhawkforum.com/forum...ht=factory+pro
Old Dec 21, 2009 | 12:14 AM
I installed the whole Factory pro kit some time ago,, and really do not remember any hidden bolts or fasteners, once you remove the water pump cover (3 of those fasteners go through the cover and into the case, so must be removed to get the cover off) and the 13 other fasteners holding the cover on.. you should be good.. There are two indexing dowel pins that can make the cover a bit of a pain to remove if it has not been off before.. look at the parts picture online http://fiche.ronayers.com/Index.cfm/...oup/WATER_PUMP
to see where they are
Old Dec 21, 2009 | 05:28 PM
stebbdt's Avatar
COBB Member
Thanks for posting that link Inde, I'll be going into my clutch over the long winter here, this'll be of use I'm sure.
Jefers, as I'm sure you have discovered, the guys on here are full of er.. umm helpful yeah, yeah, helpful, pointers and allways there to help a fellow out. Props to you all and have a merry Xmas.
Old Dec 21, 2009 | 07:57 PM
A few taps with a rubber or soft plastic mallet worked for me to get it loose.
Old Dec 21, 2009 | 11:44 PM
jefejrs's Avatar
Thanks all, got it off. Worked a hand made pry bar carefully under one of the tabs. Shift kit installed! Stebbdt, impact wench works wonders on the clutch basket nut if you don't already have one. Thanks again all, sure more questions to follow.
Evil_Twin
May 24, 2015 05:50 AM
inderocker
Feb 19, 2010 09:23 AM
vtrider
Aug 20, 2008 11:57 AM
FTMS
Aug 14, 2008 04:54 AM
ride57
Jan 29, 2008 08:27 AM
