/facepalm 2 day old headlight blew
Old Apr 16, 2011 | 08:35 PM
geekonamotorcycle's Avatar
I am a bit nervous about this. My high-beam blew the other day so when I sealed up my exhaust(which has made a world of difference). I put in a silverstar ultra headlight. I was happy for it and then today (less than 2 days later) under hard acceleration in 4th it brightened and then blew again. I am hoping this is a known issue with the bulb (55/60w), but am afraid that the truth has to do with another failing R/R. Any Ideas on how I can test this tomorrow?
Old Apr 16, 2011 | 08:36 PM
nykuryu's Avatar
nykuryu is on a distinguished road
check the voltage specs on the bulb itself. i went threw 2 bulbs in my srad that were too high. they also ended up frying the light plugs. check the voltage at the battery on a warm bike at idle, then at 5k. voltage shouldnt be above 14.5 -/+. any higher and that may be causing the blow out.
Old Apr 16, 2011 | 08:38 PM
The person at he honda store where I picked up my exhaust gaskets said I needed a 55/60 which is what the package for the bulb said.
Old Apr 16, 2011 | 08:39 PM
nykuryu's Avatar
how did you install the bulb? did you were gloves?
Old Apr 16, 2011 | 08:40 PM
Yes I did and the low beam still works
Old Apr 16, 2011 | 08:43 PM
nykuryu's Avatar
hmmm....i would check the voltage at the battery like i said then check the voltage at the plug. wiggle it around to see if you get a short to happen in the line somewhere.
Old Apr 16, 2011 | 09:02 PM
The eastern beaver site is silly hard to navigate. I cannot figure out which RR kit I am supposed to buy not can I figure out which relay works for my bike.
Old Apr 16, 2011 | 09:55 PM
If I do need another R/R this model would be a drop in right?
93 94 Honda CBR 900RR Voltage Regulator Rectifier
seems like honda used it all over the place and it has fins compared to my matchbox RR
Old Apr 16, 2011 | 10:08 PM
nykuryu's Avatar
i wouldnt go old school. the whole point of replacing your RR with another RR is to get the modern technology and manufacturing tolerances of newer RRs. i would say that RR would be as bad or worse then your factory one.
Old Apr 17, 2011 | 02:20 AM
You do know that I wrote a "manual" complete with a list of what R/R's are a good replacement, just a week or two ago, right?
https://www.superhawkforum.com/forum...why-how-25117/
Old Apr 17, 2011 | 09:11 AM
Lol tweety you are awesome
Old Apr 19, 2011 | 12:20 PM
I contacted Jim at eastern Beaver about what parts I should order and he said google it lol.
In any case this is what I ordered for an FH011 "big fin" R1 R/R. Maybe someone else can use this info.
Description Unit price Qty Amount
3P250WP-QLW-Female Connector Set
Item# 3P090WP-QLW-Set $18.62 USD 1 $18.62 USD
5P250-305K Male Housing Only
Item# 5P250-305K-M $3.29 USD 1 $3.29 USD
CNA-M250-TL-2 Terminal
Item# CNA-M250-TL-2 $0.24 USD 3 $0.72 USD
CNA-M312-TL-2 Terminal
Item# CNA-M312-TL-2 $0.33 USD 2 $0.66 USD
Subtotal $23.29 USD
Shipping and handling $5.82 USD
Total $29.11 USD
Payment $29.11 USD
CrickiKaze
Aug 23, 2014 03:21 AM
jerryh
Oct 10, 2013 10:56 PM
raylohne1
May 1, 2012 12:03 PM
EngineNoO9
Sep 2, 2006 09:15 PM
igeorgei
Sep 21, 2005 12:22 AM
