ENGINE TICKING HARD
Old May 1, 2011 | 12:55 PM
smk2mch87's Avatar
smk2mch87 is on a distinguished road
ENGINE TICKING HARD
ok so i just bought the 98 with 20k on it 2 weeks ago froom a guy i know that babied it.. Its been runnin nice n quiet until 2day, i was runnin down the freeway @ 80ish when i heard some noise. So i pull over n it doesnt sound like a knock, just a real hard ticking. It doesnt stop at anytime, but the sound kinda fades at around 4k rpm. Please help
Old May 1, 2011 | 01:20 PM
nykuryu's Avatar
nykuryu is on a distinguished road
Did you check your timing? Maybe just valve clearance?
Old May 1, 2011 | 01:33 PM
smk2mch87's Avatar
havent checked anything yet, rode 2 my buddys house, he said it sounds like a bent valve. its def coming from the front jug
Old May 1, 2011 | 01:53 PM
nykuryu's Avatar
well if its a bent valve then i dont think the noise would go away. i assume you havent done the MCCT upgrade yet?
Old May 1, 2011 | 02:39 PM
smk2mch87's Avatar
no i havent done mcct yet, its comin now tho, n the noise isnt going away at all, just kinda fades away maybe b/c its reving so fast i cant hear it as well. can u tell me how to check the cct and timing?
Old May 1, 2011 | 02:44 PM
RWhisen's Avatar
Former Superchicken Owner
I wouldn't start or ride it until you investigate the valves.
Old May 1, 2011 | 03:35 PM
nykuryu's Avatar
well first pop the little round cap on the stator cover off. that will give you access to the crank bolt (turn counter clock wise). then get that little cap right next to it off, that will let you see the timing marks. then take the valve cover off so you can see the cams. now turn the motor over til you see FT in the little cap hole and line up the lines. now look at the cams. you should just be able to see above the surface of the head FE and FI on the outside edges of the cams.
Old May 1, 2011 | 04:16 PM
smk2mch87's Avatar
k ima dig into it this week, and no im not starting it anymore lol
Old May 1, 2011 | 04:18 PM
smk2mch87's Avatar
oh 1 more ? does a 98 have adjustable valves? im thinking of caming it since i have to strip her down
Old May 1, 2011 | 05:06 PM
nykuryu's Avatar
like adjust the cam timing? no it doesnt.
Old May 1, 2011 | 05:14 PM
smk2mch87's Avatar
no im sayin like when u put in performance cams u have to grind down ur valves usually unless theyre adjustable, oh well i dont think ima have the money to do it after all this nonsense
Old May 3, 2011 | 06:52 PM
smk2mch87's Avatar
ok so i got mcct's yesterday off krieger out of ohio. he is the man n knows his stuff. put em in today and when i got to the front cyl i pulled the cam cover and noticed i jumped probably around 10 teeth. thats why it was hittin so hard. ive adjusted everything n got the cover back on... sounds like everything is right again. Havent buttoned everything up but will tomorrow n see how it sounds when running, but when i turn the motor it sounds gnarly. thx to every1 who helped with advice n deff thx 2 krieger cct's
Old May 3, 2011 | 07:30 PM
nykuryu's Avatar
dude if you jumped 10 teeth you probably bent some valves bro
Old May 3, 2011 | 09:30 PM
lukenukem47's Avatar
Where can I get a dependable head gasket set and gaskets. I'm about to do a head swap
Old May 4, 2011 | 07:53 AM
nykuryu's Avatar
Get them through a dealership. Should be about 30 bucks a piece, genuine Honda. 8541 has a link for cheap Honda parts. Either pm him for it or search around. He's posted it recently
Old May 4, 2011 | 08:15 AM
Thanks
Old May 4, 2011 | 03:44 PM
smk2mch87's Avatar
nope valves sound good man... i tied everything up today but now im spittin oil outta the top of the front cover, wtf any ideas on that? bolts r tight n sealed good
Old May 4, 2011 | 04:53 PM
smk2mch87's Avatar
nvrmmind the last post my gasket is shot in several places, this is a shitty project when things dont go the way u want em to
Old May 5, 2011 | 01:44 PM
klx678's Avatar
Just hangin' out
klx678 is on a distinguished road
If everything worked out, the last thing I'd be complaining about is a damaged or wasted cam cover gasket man!
Glad to hear it appears to have worked out. Gimme a call, let me know for sure.
Old May 5, 2011 | 05:15 PM
smk2mch87's Avatar
rvt'd the whole gasket, thatll get me through til thursday when the new gasket comes. other than that the bike sounds n runs great. Feals like a have alot more power after not ridin 4 a few days lol
Old May 5, 2011 | 06:56 PM
nykuryu's Avatar
well thats good. you are among the few that escape motor damage.
Old May 6, 2011 | 06:00 PM
smk2mch87's Avatar
ok well i do seem to have a problem, i did the bafflectomy a few days b4 the ccts took a dump. ran fine minus the carb fart at 3k rpm. ran 140 no prob. today i was finally able to get on it and the bike stumbles at 7-7500 rpms. wont go past that. also my starter has a weird whine when i hit it any ideas on either of those?
CruxGNZ
Sep 25, 2015 05:51 PM
peterdamian2000
Dec 7, 2012 06:05 PM
seb421
Mar 18, 2009 04:54 AM
The Hawk Guy
Sep 9, 2007 12:26 AM
PHPERFORMANCE
Sep 3, 2006 05:35 PM
