engine swap saga...continued
Old May 16, 2012 | 11:00 AM
blamecanada's Avatar
blamecanada is on a distinguished road
In other threads I posted I had a swap done by a shop and the bike was running poorly, they had chopped up the airbox, and pretty sure didn't connect up all the evap stuff correctly, etc...
ok so today I went through all the vacuum lines, removed both evap valves and removed the pair system, and I capped everything off except for the carb vent hoses.
I wonder is it possible that the bike was jetted to run with the vacuum leak I may have had and so now it is too rich?
I had a hard time getting it to start, and once it was started and running (sounded better than before at idle) when I tried to rev it over 3000 or engage the clutch and roll on enough throttle to move it would just die...
Progress...not really, since I went from a shitty running bike with a massive flat spot to a bike that I can't ride anywhere
Old May 16, 2012 | 11:04 AM
RWhisen's Avatar
Former Superchicken Owner
PVLIR?
Old May 16, 2012 | 11:05 AM
(for the pair thing I followed the forum guide and flipped the reeds, then removed the hoses and the pair valve itself)
Old May 16, 2012 | 11:06 AM
Originally Posted by RWhisen
PVLIR?
I wish...but I have the hoses marked so I never mix them up (after learning about PVLIR the hard way one time).
Old May 16, 2012 | 11:10 AM
RWhisen's Avatar
So you're back to carbuerators then. Pull the carbs, disassemble, clean, inspect, document and reassemble.
Old May 16, 2012 | 11:13 AM
GTS's Avatar
GTS
Seasoned tech
Have you checked to see what the jetting is?
Old May 16, 2012 | 11:28 AM
yes I need to find a good place to order some jets and I can use the carb setup thread as a baseline
Old May 16, 2012 | 11:31 AM
If you have a carb problem let me know, I'm pretty sure I can help you get them sorted.
You can either ask here or shoot me a PM and I'll send you my # if that would be easier for you
jdobeckj
Oct 21, 2012 10:16 AM
NVDutchie
Aug 15, 2012 03:29 PM
HRCA#1
Aug 17, 2008 07:41 PM
HRCA#1
May 21, 2008 05:18 PM
EngineNoO9
Nov 10, 2006 07:10 AM
