blamecanada |
05-16-2012 11:00 AM |
engine swap saga...continued
In other threads I posted I had a swap done by a shop and the bike was running poorly, they had chopped up the airbox, and pretty sure didn't connect up all the evap stuff correctly, etc...
ok so today I went through all the vacuum lines, removed both evap valves and removed the pair system, and I capped everything off except for the carb vent hoses.
I wonder is it possible that the bike was jetted to run with the vacuum leak I may have had and so now it is too rich?
I had a hard time getting it to start, and once it was started and running (sounded better than before at idle) when I tried to rev it over 3000 or engage the clutch and roll on enough throttle to move it would just die...
Progress...not really, since I went from a shitty running bike with a massive flat spot to a bike that I can't ride anywhere
