Electrical Part Help
Old Jun 30, 2021 | 08:26 AM
vtwinfun's Avatar
vtwinfun is on a distinguished road
Had a pin on the connector to Ignition Control Module break, well corrode. I’ve called a couple different Honda dealers and they have had no luck finding the pin. I have seen some that look like the same pin but are larger. Any of you happen to have a Part # or an idea of who to contact for one? Thanks.
Old Jun 30, 2021 | 04:48 PM
So is this the ICM or the plug connector? That's a tough one, doubt you'll find an available part to buy if it is what I'm imagining it to be. Might need to get a used piece and perform surgery.
Old Jun 30, 2021 | 07:07 PM
Take a look here Motorcycle Connectors
Old Jun 30, 2021 | 07:18 PM
vtwinfun's Avatar
The pins located in the connector body it’s self. I knew this was a long shot, just thought someone may have been here before.
Old Jun 30, 2021 | 07:21 PM
vtwinfun's Avatar
brilliant! This should help me get started in the right direction! Thanks a ton!
barrysuperhawk
Jun 10, 2017 07:23 AM
motogomojo
Jul 14, 2011 06:48 AM
RK1
Jul 23, 2010 04:04 AM
Rama
Sep 18, 2009 12:21 AM
DameDiggler
Jun 22, 2005 08:11 PM
