Electrical issue
Old Jul 15, 2011 | 11:37 PM
MikeMcW's Avatar
MikeMcW is on a distinguished road
Electrical issue
here is the story. I went to ride my bike on thursday and the battery was dead. Charged it this morning rode to work no issues. Put about 100 miles on after work and then my battery was smoking. I pulled the battery and its hot. Battery is probably fried and no good. But where do I start. Obviously something is causing a draw which killed the battery but what is causing it to heat up and smoke?
Old Jul 15, 2011 | 11:48 PM
The regulator\rectifier is toast. You also should check all the ground points and connectors on the wiring harness.
Old Jul 16, 2011 | 03:40 AM
MikeMcW's Avatar
I was wondering if that was the problem as I had to replace the one on my cbr as well. Is this a common problem with these? Is there a recommendation to use one out of another bike?
Old Jul 16, 2011 | 05:40 AM
scottiemann's Avatar
very common problem... many solutions for this use the search function there are hundreds of posts on this topic
mine has roasted itself many times and you have the same symptoms
Old Jul 16, 2011 | 06:06 AM
MikeMcW's Avatar
I have replaced the regulator. I'm getting 14v the battery but I'm getting a clicking noise when trying to start. But the bike will bump start. Did I fry the battery or is something else wrong?
Old Jul 16, 2011 | 06:31 AM
Are all of your lights and electrical on? You probably should check through your fuses (including the main, which is located in a different spot). You may have fried your starter relay or something which is why the starter isn't working.
Old Jul 16, 2011 | 08:26 AM
MikeMcW's Avatar
The battery was bad. It was reading 14v but when put on a load tester it dropped to nothing. Put a new battery in and we are up and running.
Old Jul 16, 2011 | 08:47 AM
Mattaua's Avatar
Mattaua is on a distinguished road
what kind of R/R did you replace the stock one with? In the long run a finned/mosfet type is the way to go...and yes the battery will almost always be fried after your R/R goes bad. Glad you got her up and running again. I had the same thing happen to me two times while riding down the road, it was shittastic.
Old Jul 16, 2011 | 08:59 AM
if your battery was smoking or bulging and steaming chances are even if you get 14 volts there could be 1 or a few dead cells and your battery is fried...
most auto parts stores will load test your battery for free and if you cant find any paperwork on the battery and it doesnt say on the battery I think its around 100 to 140 cranking amps.
Old Jul 16, 2011 | 10:28 AM
If you just put a new battery in without fixing the cause of the problem, it will be fried in no time flat.
Old Jul 16, 2011 | 11:12 AM
Tormoz's Avatar
Tormoz is on a distinguished road
This charging-system troubleshooting flowchart helped me.
Old Jul 17, 2011 | 07:06 PM
MikeMcW's Avatar
I intended to use a MOSFET rr but the cycle store in the area I was in had a used stock one. So I got that installed with a battery and have put on 200 milesvwithout any issues.
kraher
Jun 24, 2010 04:33 PM
98ILVTR
Mar 15, 2010 06:19 PM
superman_006
Mar 1, 2010 07:52 AM
Blurpy
Aug 20, 2004 06:52 PM
Blurpy
Aug 19, 2004 08:35 PM
