Electrical Gremlins
Old Feb 16, 2011 | 03:57 PM
wildride21's Avatar
wildride21 is on a distinguished road
Electrical Gremlins
I am having a problem with the neutral safety switch. bike running will go into gear and shut off with the kickstand up. will not start holding the clutch in while its in gear. i have taken the sensor off the kickstand it still shuts it off. what would be the most logical problem?
Old Feb 16, 2011 | 04:04 PM
Did you just remove the switch or did you remove it and install a jumper wire?
Old Feb 16, 2011 | 04:10 PM
wildride21's Avatar
I have done both now and it is still shutting off
Old Feb 16, 2011 | 04:41 PM
wildride21's Avatar
found the problem had a broken wire in the harness itself. the stand switch is bad also
wildride21's Avatar
thanks for the help. gave me an idea to look in the harness
bugsy27
Jan 12, 2014 01:16 AM
Skrapper68
Mar 19, 2010 10:07 AM
jonesey
Aug 9, 2009 01:29 AM
smokinjoe73
Aug 6, 2008 04:21 PM
elijahawk
Oct 13, 2007 03:56 PM
