Elec. Problem - VTR Got Towed
Old Apr 12, 2014 | 06:30 AM
nnjhawk02's Avatar
So, Thinking my baby was ready for Spring - I rode down to Philly to see some friends on Thursday -Friday on way back - with a slight hangover. The instrument cluster went out - no tach, speedo, temp., etc.
I knew I was low on gas, so I crossed in NJ (cheaper petrol than Pa - I was on Rt.32 north of New Hope, Pa)
So U know what happens next - VTR doesn't start - (I have a new battery BTW)
So I jump start it and continue the road home - within 10 mins. it starts losing power, stalls as I'm riding & I just jump it again.
Then it starts to backfire & I decide to cut my loses and pulled over & called the AMA towing service.
So, I'm thinking CDI unit? or R/R? (These have both been replaced, but not recently)
CDI unit was replaced July 2010 and the R/R I think in '08 or '09.
I don't have a multimeter - so info from the class would help
Some pics from breakdown area & tow
And if U don't have a tow service - I would join the AMA - U get free towing for all ur vehicles - Yes thats right - cars too and it includes ur family as well. (Free towing up to 35 miles) I was 20 miles from home.
Old Apr 12, 2014 | 07:09 AM
What did you replace the R/R with OE or upgrade? Did you have a look at its wiring harness? Mine was starting to show signs of heat fatigue.
Old Apr 12, 2014 | 08:02 AM
nnjhawk02's Avatar
Found my receipt for the R/R - from Ricks OEM style from 5 years ago.
And yes one of the wiring harnesses with I think all yellow wires has heat stress.
Course of action now should be what?
Clip the wires and get a new connectors?
Thanks
Old Apr 12, 2014 | 08:07 AM
See post #1.
Old Apr 12, 2014 | 08:29 AM
nnjhawk02's Avatar
Giddyup
Ordering stuff to commence
FYI - the wiring harness that I looked out that was distressed was under the seat & not the R/R connector. I will check that as well.
Thanks
And would U suggest a R1 type R/R or the Mosfet?
Old Apr 12, 2014 | 08:49 AM
RoadManiac's Avatar
European Member
Yes a Mosfet R/R is the best option
you will need one with on it FH ****
Do a search for : wich R/R and you will find anything you need
Old Apr 12, 2014 | 01:13 PM
nnjhawk02's Avatar
Mas informacion
So started to take apart the VTR
And - I relooked at the alternator connector (located by behind gas tank)
might this be the culprit?
I'm going to change this and see if that was the problem.
Alt. Connector
As the R/R connector doesn't looked burned - thus I'm not sure if the R/R is the problem
Old Apr 12, 2014 | 03:24 PM
jefejrs's Avatar
jefejrs is on a distinguished road
I would change it anyways...Eastern Beaver harness and Mosfet R/R..no worries..
Old Apr 12, 2014 | 06:06 PM
Mikael's Avatar
Mikael is on a distinguished road
I would get the Eastern Beaver wiring kit, plugs right in nice new connections and wires AND a new MOSFET R/R as you don't know if your old one is bad and no easy way to test.
Plus the MOSFET ones are better than the crappy OEM ones the bike came with.
Read this, explains the difference and a big plus gives you a list of what R/R's are MOSFET
https://www.superhawkforum.com/forum...why-how-25117/
Old Apr 13, 2014 | 08:15 AM
nnjhawk02's Avatar
Thanks guys
I will be ordering the MOSFET & new connectors.
1 thing though
Eastern Beavers web site is confusing - do they sell R/R units or just wiring kits?
Old Apr 14, 2014 | 06:57 AM
nnjhawk02's Avatar
Update & Info Help Others Too
So I learned that Eastern Beaver does not sell R/R - just wiring kits.
Jim from EB emailed me back yesterday & stated as such & told me what wiring kits I needed & to order a FH020 R/R, as that is the latest tech on the MOSFET units.
I went to ebay & or got this
Universal Motorcycle Regulator Upgrade Kit Shindengen MOSFET FH020AA | eBay
And free fast shipping as well.
I hope my failed R/R hasn't screwed up my new battery.
Old Apr 14, 2014 | 10:25 AM
AgDroid's Avatar
AgDroid is on a distinguished road
I ordered my R/R wiring kit from Shindengen FH020AA Mosfet Regulator/Rectifier I got the R/R on e-bay on it's own, it's a quick and easy install. Solder free if you just want to use the crimp connections.
I'm not sure if it could have permanently damaged the battery, but R/R failures can junk clusters from time to time. Hopefully everything lights up once you get it up and running again.
Old Apr 14, 2014 | 02:29 PM
You won't regret that purchase Rhino. High quality connectors and everything in one makes it convenient. Follow that swap thread and don't forget to slide the boots on before you crimp. Your R/R will no longer be an issue.
Old Apr 14, 2014 | 04:46 PM
nnjhawk02's Avatar
10-4
Thanks
Just ordered the EB kits. Hope to be on the road shortly.
I'll have to ride to G-Burg to see the sites
Old Apr 15, 2014 | 09:58 AM
Part of the problem may be that you top case tips the wrong way and causes un-needed instability away from bike center of mass.
Tilt it forward/ closer and the bike will handle and (maybe) run better.
Old Apr 15, 2014 | 01:27 PM
nnjhawk02's Avatar
U funny round eye
Old Apr 27, 2014 | 01:40 PM
nnjhawk02's Avatar
Help
1st - sorry if I come off dumb here, but help me, if ya would - thanks
OK - I'm finally getting around to installing the new MOSFET R/R. As stated I have a Eastern Beaver wiring kits - EB known as A & B.
EB A is easy into black R/R connector, then to battery.
EB B is where I'm confused. I know where it goes for the R/R (thats easy there's only one more connection left), but I plug into the OEM female Alternator connector, but I've bypassed the OEM male alt. connector.
I'm guessing I don't need it anymore?
This male alt plug
Old Apr 27, 2014 | 01:48 PM
nnjhawk02's Avatar
Help - Part 2
HMmmm
I think I got it.
The OEM Alt male 3 yellow wires went to the OEM connector for the OEM R/R - correct?
And now I don't need them, si?
Old May 2, 2014 | 05:04 AM
nnjhawk02's Avatar
Wake the kids & Call the neighbors, I finally got my baby back together & RUNNING!
Was very frustrating, especially the alternator wires (3), tiny & not enough slack after I clipped off the old female connector. So with a MOSFET R/R & a Eastern Beaver wiring kit, its all working now.
I was so happy to have it running that I washed & waxed her too.
I really hate working with things in tight spaces.
Now I just need to change a flat on the Mtn Bike & clear coat the wifes vans hood after I did some body work - I man's job is never done...
Goku dua
Mar 27, 2014 05:15 AM
bostonhawk
Sep 1, 2012 08:45 AM
j shizzy wizzy
Nov 15, 2010 10:50 PM
RIHDER34
Jul 15, 2009 12:39 PM
moisesdtp
May 28, 2006 01:49 AM
