dynojet het kit, drilling?
Old Oct 22, 2009 | 03:40 PM
uchi's Avatar
the guy whos got my bike is in the process of jetting it and the kits instructions say something about drilling somethign out, i dont have them handy so i dont know exactly what it is but the guy whos doing the work is saying that on the jet kits hes done on other bikes there was never any drilling involved. wondering what this is for and if its neccessary?
edit, just noticed i put het kit, damn my lazyness and lack of proof reading
Old Oct 22, 2009 | 03:43 PM
Yes, it is necessary, you won't be able to tune the DJ kit well without doing it. (this is why the Factory Pro kit is preferred for self install as it doesn't need the slides drilled)
What you are doing is drilling the slides so that they open faster. I haven't done it, but my understanding is that the kit comes with a template for where to drill.. Just be sure to get it right as you only get one chance.
Old Oct 22, 2009 | 03:53 PM
uchi's Avatar
alright thanks for the help. can we safely assume that the dj kit can be setup using the same settings as the factory kits?
Old Oct 22, 2009 | 03:57 PM
comedo's Avatar
Factory Pro main jets are numbered as Keihin main jets are. Dynojet numbers its main jets differently. A 185 main jet from Factory Pro is not the same as a 185 main jet from Dynojet.
Old Oct 22, 2009 | 05:54 PM
uchi's Avatar
Is there a site with a reference chart I can use?
Old Oct 22, 2009 | 05:59 PM
Little_Horse's Avatar
2nd mouse gets the cheese
drilling the slides is so you can utilize the shorter spring that the kit comes with. If you don't know how to drill the slides or just don't want to mess with that you can just reinstall the longer springs. I actually like having the shorter spring as it make re assembly alot easier. If you drill make sure to have the clip retainer installed in the slide as you will need to drill both at the same time.
Old Oct 22, 2009 | 06:14 PM
uchi's Avatar
gotcha, thanks for the info.
i found a chart and yeah its off. lol. anyone on here running a dynojet kit with a slip on and k&n at sea level?
Old Oct 22, 2009 | 06:23 PM
uchi's Avatar
heres what i found, im trying to search through here but there search results are endless. so for me to want to run a 188 factory jet sized jet id have to run a 168 dj jet correct?
Width------Keihin # -- DynoJets # -- Mikuni #
0.0350---- 92.5--------- 92----------- 86.3
0.0360---- 95----------- 94----------- 88.1
0.0370---- 97.5--------- 96----------- 90.0
0.0380---- 100---------- 98----------- 91.9
0.0390---- 102.5------- 100---------- 93.8
0.0400---- 105--------- 102---------- 95.6
0.0410---- 107.5------- 104---------- 97.5
0.0420---- 110--------- 106---------- 99.4
0.0430---- 112.5------- 108--------- 101.3
0.0440---- 115--------- 110--------- 103.1
0.0450---- 117.5------- 112--------- 105.0
0.0460---- 120--------- 114--------- 106.9
0.0470---- 122.5------- 116--------- 108.8
0.0480---- 125--------- 118--------- 110.6
0.0490---- 127.5------- 120--------- 112.5
0.0500---- 130--------- 122--------- 114.4
0.0510---- 132.5------- 124--------- 116.3
0.0520---- 135--------- 126--------- 118.1
0.0530---- 137.5------- 128--------- 120.0
0.0540---- 140--------- 130--------- 121.9
0.0550---- 142.5------- 132--------- 123.8
0.0560---- 145--------- 134--------- 125.6
0.0570---- 147.5------- 136--------- 127.5
0.0580---- 150--------- 138--------- 129.4
0.0590---- 152.5------- 140--------- 131.3
0.0600---- 155--------- 142--------- 133.1
0.0610---- 157.5------- 144--------- 135.0
0.0620---- 160--------- 146--------- 136.9
0.0630---- 162.5------- 148--------- 138.8
0.0640---- 165--------- 150--------- 140.6
0.0650---- 167.5------- 152--------- 142.5
0.0660---- 170--------- 154--------- 144.4
0.0670---- 172.5------- 156--------- 146.3
0.0680---- 175--------- 158--------- 148.1
0.0690---- 177.5------- 160--------- 150.0
0.0700---- 180--------- 162--------- 151.9
0.0710---- 182.5------- 164--------- 153.8
0.0720---- 185--------- 166--------- 155.6
0.0730---- 187.5------- 168--------- 157.5
0.0740---- 190--------- 170--------- 159.4
0.0750---- 192.5------- 172--------- 161.3
0.0760---- 195--------- 174--------- 163.1
0.0770---- 197.5------- 176--------- 165.0
0.0780---- 200--------- 178--------- 166.9
0.0790---- 202.5------- 180--------- 168.8
0.0800---- 205--------- 182--------- 170.6
0.0810---- 207.5------- 184--------- 172.5
0.0820---- 210--------- 186--------- 174.4
0.0830---- 212.5------- 188--------- 176.3
0.0840---- 215--------- 190--------- 178.1
0.0850---- 217.5------- 192--------- 180.0
0.0860---- 220--------- 194--------- 181.9
0.0870---- 222.5------- 196--------- 183.7
0.0880---- 225--------- 198--------- 185.6
0.0890---- 227.5------- 200--------- 187.5
Old Oct 22, 2009 | 06:29 PM
thetophatflash's Avatar
4strokes.com has a good cross reference. I got it here in june.
Old Oct 22, 2009 | 06:38 PM
Well you'll get different answers to that question. I ran that set up for a while and never got it to work right.
The hole that needs to drilled is an extra "lift" hole. It allows the vacuum slide to open faster along with the shorter spring. It is easy to drill and the kit comes with the drill and a jig, just follow the instructions and there should be no problem.
In my case, the bike runs better with a larger pilot jet and a slower slide movement. Which is what you get with the Factory kit or the HRC kit
The Factory kit is easier to install and tune and is the most common kit used.
The HRC kits are very rare and not really worth the big $$ you will pay, if you can find one, but it is what I am running. If you are real picky, they do work pretty good, if you know a couple of set up tricks for them.
If I had it to do all over again, I would go with either the Factory kit or just shim the needles .040-.060 and go up one size on the pilot jet and start tuning from there (as all bikes as different, so you will have to dial it in for your bike) also I went back to the stock air filter as recommended to me while I was tuning mine
Old Oct 22, 2009 | 06:41 PM
uchi's Avatar
yeah for sure. were just trying to get a good base so we can tune it from there. doing some reading im guesssing the dynojet wasnt a great idea but i got it for a good price and couldnt pass it up.
Old Oct 22, 2009 | 06:59 PM
No worries.....
I'm sure someone here can give you some set up tips, I wish I could help but I pulled the kit around 8-9 yrs ago and don't have my notes anymore.
Old Oct 22, 2009 | 07:11 PM
uchi's Avatar
thats alright man, im just glad to be led in the right direction, lol
Old Nov 29, 2009 | 06:22 AM
c-dub's Avatar
c-dub is on a distinguished road
how did your tuning go?
i am at sea level with k&n, 2-bro full system... shop set me up with my dynojet kit, drilled, 180/185, clip setting #6, fuel mixture 3 turns out... i think its a little fat... just moved the clip to #5 and went to 2.5 turns out on fuel mixture...
ordered more mains - interesting read on the pilot changes - i wish it was warmer to ride and really go through this in a series of test sessions... cant wait to get it back together!
when i ordered in 1999 the kit recommended 180/185, needle #4... they updated the jet kit later with recommended 190/195, needle #5 position if you have exhaust and k&n.
Old Nov 29, 2009 | 06:46 AM
FWIW, I was specifically told by Roger Ditchfield of Revolution Racing in the UK (a VTR tuner extraordinaire and user/installer of DJ kits on VTRs) NOT to drill the slides for street use.
Old Nov 29, 2009 | 06:51 AM
Although I have not tried a Factory kit on a VTR, I can safely and confidently say that a well-tuned DJ kit on a VTR is VERY HARD to beat. I have been running one in mine for a few years now (in various states of tune, with the necessary adjutsments made along the way) and can honestly say that my VTR runs spot-on at all speeds and throttle openings. In fact, I have yet to ride another bike (FI or otherwise) that is as responsive and free of glitches.
Old Nov 29, 2009 | 07:13 AM
c-dub's Avatar
well, its a little late for me on the drilling, since it's a done deal... and in the instructions too.. i guess if you have a dyno etc, you can more easily get dialed in if you dont follow the recommendations as a baseline...
i am just looking for more bottom end hit / mid range...
Old Nov 29, 2009 | 07:37 AM
c-dub's Avatar
nice to hear -
do you know your current settings for mains, clips, fuel mixture?
Old Nov 29, 2009 | 08:29 AM
cliby's Avatar
My experience was more like 8541Hawk. The DJ kit was fine for slipons but after going to cams and full exhaust I could not get it perfect. And I tried everything and had a very reputable Vtwin expert try on the dyno as well. The full exhaust is really what changed it - required a big jetting change to smaller jets and the slidedrill and light springs made it impossible to get smooth transitions. Finally took 8541Hawk advice, found some HRC parts and its run perfect since. But I bet which kit works or doesn't depends on the combination of mods you have, as Mikstr indicates
Old Nov 29, 2009 | 09:29 AM
Originally Posted by c-dub
nice to hear -
I could locate them but they wouldn't be of much use to you as our set-ups are waaaaaaaaaay different (see my signature).
Old Nov 29, 2009 | 09:36 AM
c-dub's Avatar
uhhh - yeah, whoah my bad... you have done just a few things, huh??!?!?
Old Nov 29, 2009 | 10:12 AM
It has evolved over time. I was running Micron slip-ons only when I first got the DJ kit installed. It helps to be able to call on a knowledgeable tuner to help iron out any problems (something I was fortuante to have). That being said, the final round of calibrations carried out this summer (after the velocity stacks and Akra exhaust were installed) I did myself and had great results. Each bike is different to some degree, as is every mod combination. So, while I can understand that perhaps others have not had the best results with a DJ kit, every time I ride my bike I am blown away with just how well it runs in terms of carb calibration.
Old Nov 29, 2009 | 10:37 AM
uchi's Avatar
my buddy john did the jet kit for me, when i went there it was setup exactly the same way that the manual has it to be setup for a k&n with slipons, but my cans are cut and right now shes lean, so when we pull out the choke she cleans right up and revs smoothly. i ordered the tool to adjust the screw on the carbs without having the yank the carbs so itll make tuning that much easier.
Old Nov 29, 2009 | 11:51 AM
c-dub's Avatar
do you know the main you have now? are they the 190/195 deal on the new kits? and still lean... oh my... i am in a really differnt place
Old Nov 29, 2009 | 04:50 PM
Uchi, where in the rev band are your carburetion problems?
Flashhart
Feb 25, 2010 10:05 AM
hymey
Aug 25, 2008 07:46 PM
EngineNoO9
Feb 17, 2007 03:03 PM
Speed_Demon
Feb 16, 2007 08:24 AM
