Draining Coolant
Old Jul 14, 2007 | 01:22 PM
bowhawk's Avatar
Draining Coolant
I have to drain the coolant and replace it with water for some upcoming track days. Just thought I'd ask if anyone has any tips or bad experience with running just water. I was going run water until the end of the summer. Thoughts?
Old Jul 14, 2007 | 03:33 PM
marmaladedad's Avatar
Hmm?
I would recommend running water + Water Wetter. It has better cooling properties than straight-water.
You'll definitely want to switch to antifreeze coolant for the cold temps.
Old Jul 14, 2007 | 06:17 PM
SD996's Avatar
SD996 is on a distinguished road
If you run only water in a dirt bike it will seize the engine. I think the same thing would be true for a street bike. I'm no expert, but I beleive antifreeze also acts as anti-boil. They make special coolant specific for track use.
Old Jul 14, 2007 | 07:08 PM
azhawk1's Avatar
azhawk1 is on a distinguished road
I would run engine ice personally
Old Jul 14, 2007 | 07:14 PM
kevink2's Avatar
kevink2 is on a distinguished road
I think with straight water you are also risking corrosion.
Old Jul 14, 2007 | 08:05 PM
Hmm?
Some trackday providers/organizers specify against EI because it has a glycol (I think...?) based additive that makes it as slippery as antifreeze.
Old Jul 14, 2007 | 11:12 PM
Chitownson's Avatar
Chitownson is on a distinguished road
Straight water
I'm no expert but I believe you have to have some kind of lubricant/additive for water pump.
CruxGNZ
Apr 29, 2013 03:56 PM
Unzie57
Oct 22, 2012 06:30 PM
Super-Rob
Jul 30, 2010 10:08 AM
05xman
Sep 22, 2007 06:40 PM
faz
Jul 29, 2004 10:58 AM
