Down On Power - CCT Issue?
Old May 10, 2017 | 08:01 AM
RonVTR's Avatar
RonVTR
Hi, I searched and read many CCT related articles on this forum however didn't find anything that specifically referenced my symptoms... Maybe someone here can confirm if this is a CCT related issue?
While down shifting through the gears - The Superhawk's Stain-tunes sound so good doing this - I felt a little 'hick up'. After that moment, it was noticeably down on power. It starts and runs but feels more like a 750cc VTR. After failing to find anything wrong, I decided to take it into the dealer.
Dealer did a compression test and leak down test. Here are the results:
Leak Down: F = 15%, R = 20%
Compression: F = 115, R = 120
My VTR is a 1998 with 32,000 miles. It has the original CCTs.
Thanks
Ron
Old May 10, 2017 | 09:15 AM
Wicky's Avatar
airfilter? hoses esp vacuum firmly in the right place with no holes/spilts? - same for the petcock diaphragm. Carbs need cleaning - gummed up? old fuel?
Plugs?, plug caps firmly on?
CCT failure is binary - either they work or they don't - with the bike producing the sound of a cement mixer full of metalic junk...
Old May 10, 2017 | 09:34 AM
Are you mechanically inclined enough to pull the cam covers and check timing?
This is the next step I'd take.
Old May 11, 2017 | 07:38 AM
RonVTR's Avatar
RonVTR
Just an update... I asked the dealer to check engine timing yesterday.
Old May 11, 2017 | 03:08 PM
Get them some manual cct's and never worry about it again! You're on borrowed time.
Old May 13, 2017 | 08:16 AM
There are good mechanics and not so good mechanics. I hope your luck falls to the former.
Let "borrowed time" guide you decisions.
chemomche
Nov 13, 2012 12:26 AM
jdobeckj
Apr 5, 2012 07:44 PM
superman_006
Mar 1, 2010 07:52 AM
radbikers
Feb 23, 2008 05:02 PM
BiggDaddyKool
Jun 7, 2007 03:52 PM
