Do your valves look like this?
Old Nov 19, 2009 | 10:06 PM
avramd's Avatar
avramd is on a distinguished road
Yikes, I was shimming my jet needles today, and I happened to glance down into the intake manifold with a light shined directly into it - this is like the 8th time I've had the carbs half-removed, but just never really looked down there before.
Holy christ, the back-sides of my valves look like crap - all brown-blackish and gunky-crusty. Is this normal? Is it a problem? If so, is there any way to clean them up besides taking the head off and taking them out?
I'd appreciate it if anyone who's had good looks at lots of valves could comment on these pics. Sorry, they're not the best, taken at night.
Do your valves look like this?-imgp1052.jpg Do your valves look like this?-imgp1055.jpg Do your valves look like this?-imgp1058.jpg
Old Nov 19, 2009 | 10:35 PM
jbaxx's Avatar
Honducati
Use a good quality fuel like Chevron. Also rev the pee pee out of it occasionally.
Old Nov 19, 2009 | 10:46 PM
Just_Nick's Avatar
Who are you?
Fuel isn't different, the additives that are dumped in the tanks are the only difference.
Your best bet is to run something like Sea Foam every once in a while. Add 4 oz, or a quarter bottle, into the tank at fill-up and drive the **** out of it.
Old Nov 20, 2009 | 01:25 AM
yellowstorm's Avatar
dave
yellowstorm is on a distinguished road
if there is white krusty bubbles on top of the valve you may have a little water mixed with your fuel try some new fuel
Old Nov 20, 2009 | 07:25 AM
Jim TT's Avatar
Jim TT
That is rather normal but the advice above is good. JIM
Old Nov 20, 2009 | 07:53 AM
mboe794's Avatar
Yeah, intake valves usually have some crud on them. You may be able to reduce it but probably not eliminate it. Mine are a little dirty. I don't worry about it.
Old Nov 20, 2009 | 09:29 AM
Kendrick's Avatar
The Hypno-Toad
Yeah, thats what mine looked like when I took them out, but at least the exhaust valves were scorched nice and clean!
Old Nov 20, 2009 | 09:45 AM
Little_Horse's Avatar
2nd mouse gets the cheese
Doesn't the ethanol leave more deposits too?
Old Nov 20, 2009 | 11:07 AM
Starbucks Fueled's Avatar
Starbucks Fueled is on a distinguished road
+1, looks like good ole ethanol deposits to me. Some techron will clean that off.
AJ
Old Nov 20, 2009 | 11:18 AM
FL02SupaHawk996's Avatar
Fastest Color
Yep, mine were bad too...let me know what you find that works?
Attached Thumbnails Do your valves look like this?-01-30-09-dirty-int-valve.jpg   Do your valves look like this?-01-30-09-dirty-int-valves-bowls.jpg
Old Nov 20, 2009 | 06:01 PM
avramd's Avatar
Is Sta-Bil equivalent to Sea-Foam?
Old Nov 20, 2009 | 06:26 PM
nath981's Avatar
no sta-bil is a fuel stabilizer you put in when you store your bike so the carbs don't get all gunked up. Sea Foam can be purchased at auto zone or other auto store. If I were you, I wouldn't be concerned about those valves.
Old Nov 20, 2009 | 07:21 PM
Mine looked the same way before the top end rebuild (unrelated - bent valves). After that I started to run only quality fuels in the bike, Shell & Chevron, and have noticed that the intake valves are a lot cleaner.
Just_Nick's Avatar
Who are you?
Negative. Like Nath said, Sta-bil is meant to keep fuel from turning bad and gumming **** up.
Sea foam is meant to clean **** out of your engine.
Old Nov 23, 2009 | 07:59 PM
avramd's Avatar
Actually, I was referring to Sta-Bil Ethanol Treatment, not Sta-Bil Engine Stabilizer, sorry. Their ethanol treatment is meant for everyday use and has an engine cleaner in it.
Kators
Dec 13, 2009 06:13 AM
Stevebis1
Mar 3, 2009 11:37 PM
dpenix76
Sep 7, 2007 09:12 PM
Brian A
Nov 28, 2006 08:15 AM
EngineNoO9
Sep 11, 2006 05:07 AM
