cush drive movement ?
Old Mar 4, 2007 | 12:09 PM
trinc's Avatar
how much movement is OK ? getting ready to put new chain & sprockets on and noticed that the cush drive is pretty loose ( maybe a 2-3 degrees ).
normally, i thought, you shouldn't feel any movement ?
of course nobody has any in stock so i'd have to express them to get the bike back together
thx
tim
Old Mar 4, 2007 | 01:06 PM
Birdoprey's Avatar
I'd say not to worry until it's noticeable when rolling on and off the throttle.
Old Mar 4, 2007 | 01:34 PM
SlowHAWK's Avatar
Mine does the same.
J.
Old Mar 4, 2007 | 02:48 PM
If you take the back wheel off you should have zero play when rotating by hand. If you have any play the rubber inserts aren't that expensive. Just a hint, spray some silicone on the rubber inserts before putting the carrier back on. They last longer that way.
RPV-Hawk
Jun 30, 2011 09:54 AM
Rollin20z
Jun 3, 2009 07:07 AM
bristunt
Feb 25, 2008 10:38 PM
NovaWildcat08
Jun 21, 2007 07:16 PM
FordsnRebels
Aug 22, 2006 06:33 PM
