cush drive movement ?
how much movement is OK ? getting ready to put new chain & sprockets on and noticed that the cush drive is pretty loose ( maybe a 2-3 degrees ).
normally, i thought, you shouldn't feel any movement ? of course nobody has any in stock so i'd have to express them to get the bike back together :( thx tim |
I'd say not to worry until it's noticeable when rolling on and off the throttle.
Mine does the same.
J. |
If you take the back wheel off you should have zero play when rotating by hand. If you have any play the rubber inserts aren't that expensive. Just a hint, spray some silicone on the rubber inserts before putting the carrier back on. They last longer that way.
