Crazy water sensor
Old Mar 2, 2018 | 02:21 PM
Vtrwanabe's Avatar
Vtrwanabe is on a distinguished road
Crazy water sensor
Hello Just want to say glad to join this forum.... now to something i think its odd that happen when i was changing the water temp sensor
i have a koso gp style gauges installed with tach and speedo and the temp was always at 0.0˚ so i tested the gauge and came to the conclusion that it was dead so i replace it with a new one but i've just disconnect the conector unscrew the sensor and install the new one my question is shouldn't the coolant splash out when i unscrew the old sensor??????
I think it migth be a problem...
thanks
Old Mar 4, 2018 | 11:31 AM
You will get a small amount while changing the sensor.....
Now if you really do want it to go everywhere, remove the radiator cap and things will be much different without the vacuum lock =)
Old Mar 4, 2018 | 12:42 PM
Vtrwanabe's Avatar
thats what i was thinking the radiator cap is allrigth thanks for the info
2404life
Mar 30, 2012 01:02 PM
smokinjoe73
Nov 9, 2010 09:39 AM
vtrlvr
Apr 19, 2007 10:21 PM
YellowHawk
Mar 24, 2007 01:40 AM
seroj
Nov 16, 2006 08:13 AM
