Crazy water sensor
Hello Just want to say glad to join this forum.... now to something i think its odd that happen when i was changing the water temp sensor
i have a koso gp style gauges installed with tach and speedo and the temp was always at 0.0˚ so i tested the gauge and came to the conclusion that it was dead so i replace it with a new one but i've just disconnect the conector unscrew the sensor and install the new one my question is shouldn't the coolant splash out when i unscrew the old sensor?????? I think it migth be a problem... thanks |
You will get a small amount while changing the sensor.....
Now if you really do want it to go everywhere, remove the radiator cap and things will be much different without the vacuum lock =) |
Originally Posted by 8541Hawk
(Post 405592)
Now if you really do want it to go everywhere, remove the radiator cap and things will be much different without the vacuum lock =) thats what i was thinking the radiator cap is allrigth thanks for the info |
