coughing through carbs!
Old Mar 27, 2008 | 11:16 AM
Stixx's Avatar
Stixx is on a distinguished road
Question coughing through carbs!
Help. Bike has started coughing back through the carbs. It idles fine but when it reaches between 2200 and 3500 rps it starts losing powerand shudders. if i run it up past 3500 it runs like it is supposed to.I have just had it painted so the tank was off but after looking through the forum for a few days i have checked that all of the lines are clear and hooked up to where they are supposed to be.the lines inside the tank are clear also. the pair valve is still hooked up, the only mods to the engine has been a k&n filter, jet kit and exhaust. all installed at the dealer. the only thing that i changed while it was getting paint is that i went from yosh low mount to jardine high mounts
Old Mar 27, 2008 | 12:28 PM
sassage's Avatar
new pipes would change the flow characteristics but I'm no carb expert either
Old Mar 27, 2008 | 12:50 PM
superbling's Avatar
You'll need to change the carb needle settings. That rpm you're now having the stumbles in is when the carbs switch between primary and main jets. The pipe change screwed with it.
Old Mar 27, 2008 | 06:47 PM
Stixx's Avatar
Thank yall very much.
Old Mar 28, 2008 | 04:02 AM
gboezio's Avatar
Back off the needles one notch (set e-clip lower), DJ are pretty conservative on the fuel, this should clear the problem.
spladle160
Nov 7, 2009 08:33 PM
punkwood2k
Sep 14, 2009 04:35 PM
Hawk9807
Nov 27, 2008 02:02 PM
Gregw
Jul 27, 2008 08:15 PM
SuperHawkins
Oct 19, 2007 09:04 AM
