Coolant leak from engine mount...
Old Apr 7, 2009 | 09:28 AM
Little_Horse's Avatar
2nd mouse gets the cheese
I have a leak coming from my engine mount on the left side. Any ideas why? Any good solutions for how to fix?
Old Apr 7, 2009 | 10:00 AM
SlowHAWK's Avatar
I'd suggest looking at the coolant reservior and the hoses from it... it's located just to the right of that bolt between the heads... and it may be leaking while on the side stand and just running down to that location.
J.
Old Apr 7, 2009 | 10:03 AM
trinc's Avatar
check the water pump seal & hoses... they are all on the left side. your probably ( hopefully ) just seeing where it ended up.
tim
Old Apr 7, 2009 | 10:11 AM
+1
It's leaking from somewhere above that location and traveling to where it is visible. You may need to remove the airbox to locate.
Old Apr 7, 2009 | 10:12 AM
so I looked a little closer and it seems the line that is leaking is the one that connects to the front cylinder under the carbs. Its about an inch od. It looks as though the clamp is tight so I am assuming then its time to order a new hose. And to think I knew I smelled coolant for a while, but could never find why. The only pain now is I am going to have to remove the carbs, "son of a..." But thank goodness not a crack or something in the case, which was my initial thought. I guess those ideas are what happen after working on my mazda truck, where hoses last longer than intake manifolds and among other things. Thanks for the help reassurances.
Old Apr 7, 2009 | 10:42 AM
Starbucks Fueled's Avatar
Starbucks Fueled is on a distinguished road
Once you've had the carbs off a few times, it goes pretty quick. You pick up the flow of things and it comes pretty easy. Of course if it had been one of the radiator hoses, it would have been a hell of alot easier.
Old Apr 7, 2009 | 10:47 AM
I have removed carbs more than 10 times and can do it in my sleep, but it still doesn't make it any less of a pain in ***. Oh well I guess coulda been worse.
Old Apr 7, 2009 | 11:01 AM
trinc's Avatar
agree ! i would be a lot easier if it wasn't for the front breather hose... & those plastic choke bolts ! removing my steering damper... etc.
tim
Old Apr 7, 2009 | 11:08 AM
cornandp, hope you get it back on the road soon. Just for reference, what year is your bike? Good to know for future hose replacement schedule.
Sometimes you get lucky, but sometimes Murphy's Law kicks in and it's the hardest hose to get to that leaks. Some of todays cars are much worse though.
Old Apr 7, 2009 | 11:19 AM
ff's Avatar
ff
ff is an unknown quantity at this point
since you're in there, i would check and replace the o-ring that seals the metal hose mount to the front cylinder too. i had one go out on me that caused a slow leak. the hose might be okay and it's just the seal that's leaking. the o-ring is cheap and i replaced both of them(one on the front head and one on the rear head)
#18 in the diagram:
http://fiche.ronayers.com/Index.cfm/...oup/WATER_PIPE
Old Apr 7, 2009 | 12:24 PM
#18 in the diagram:
thanks I should replace those too, my bike is a 2000 with 45k.
mkimber
Jan 13, 2008 06:18 PM
j_frank
Apr 28, 2007 11:40 PM
EngineNoO9
Oct 20, 2006 09:01 PM
EngineNoO9
Dec 21, 2005 06:10 AM
faz
Jul 29, 2004 10:58 AM
