Constant power wire
Old May 3, 2012 | 12:00 PM
Constant power wire
So I am installing an aftermarket dash. I need a constant 12 wire behind the dash cuz it has a clock I want to work.
Is there any constant power wires behind my 98 dash I can tap into?
Yes I can test em all but maybe someone knows
Old May 3, 2012 | 01:23 PM
aja's Avatar
aja
I wonder if you can redline on that tach lol
Paging tweety...
Old May 3, 2012 | 04:54 PM
comedo's Avatar
If you disable the rev limiter, you can redline it at 13,000 rpm. once.
Old May 3, 2012 | 06:53 PM
CrankenFine's Avatar
Per the wiring diagram in the back of the factory service manual, there should be a red wire with a green trace going to the odometer on a any 98-00 bike. Same for all other years except it also power the clock after 2000. This is a fused wire .
The red wire going to your ignition switch is also hot except direct to batt +, no fuse.
Old May 3, 2012 | 06:59 PM
Thanks cranken, thats what I was looking for.
Less thanks to the charlatans using my thread to babble......
Pics to follow on install
Old May 3, 2012 | 07:19 PM
aja's Avatar
aja
Sorry for the free bump since I was curious too but didn't know, won't happen again.
j shizzy wizzy
Mar 28, 2016 09:51 AM
Daytona
Dec 20, 2011 07:03 PM
USAFrider
Jun 15, 2007 05:29 PM
snowman666
Apr 17, 2007 06:58 AM
