Tire Watch...constant pressure/temp. monitoring!
Old Feb 6, 2009 | 12:42 PM
j shizzy wizzy's Avatar
mildly retarded
Has anyone heard of this system or used it? Its expensive, but seems like a great idea! of course, a $10 gauge would work too...
http://www.tire-watch.com/index.php?...=28&Itemid=118
Old Feb 6, 2009 | 01:09 PM
k-d-williams's Avatar
I like the idea, but its just as easy for me to check them weekly. My tires are filled with nitrogen. Since I quit using air, my pressures remain constant and do not leak (yet)
Old Feb 6, 2009 | 02:01 PM
http://motorrad.ca/index.php?main_pa...products_id=13
$375 in Canada, no USA distributors..
Old Feb 6, 2009 | 02:08 PM
300 Clams! F-that!
Old Feb 6, 2009 | 03:35 PM
CentralCoaster's Avatar
Oh don't get me started on nitrogen....
Old Feb 6, 2009 | 03:38 PM
mildly retarded
Fire it up! Is there something wrong with nitrogen? I run Nitrogen in all my vehicles. Now I think I'm gonna use it in the hawks tires. I don't know why I haven't all along!
Old Feb 6, 2009 | 04:17 PM
Yep, I too would like to know what your aurgument is on using nitrogen.
Old Feb 6, 2009 | 05:45 PM
MLB's Avatar
MLB
MLB is on a distinguished road
There's nothing wrong with nitrogen.
Just no advantages either.
Old Feb 6, 2009 | 06:19 PM
The one advantage it has is that with the right mix, you have less variation in tire pressure with temperature... Not myth... fact... But other than that it's the same...
And the price you pay to get it in there is insane...
Old Feb 6, 2009 | 06:37 PM
Normal air is 79% nitrogen, 20% oxygen and 1% misc (mostly argon)..
So if you keep inflating your tires, and mostly the oxygen leaks out over time.. eventually it will be nitrogen filled with just using normal air!! lol (really, the differences are not measurable unless you only check your tire pressure once a year)
Old Feb 6, 2009 | 07:12 PM
Byrdman's Avatar
Super Byrd
most paintballers use nitrogen in their tanks so their pressure doesn't fluctuate
Old Feb 6, 2009 | 07:18 PM
mildly retarded
I have been told, basically, nitrogen molecules are larger than oxygen's and leak at a slower and more consistent rate. We still need to check our pressure regularly of course, but it just helps with gas mileage and tire wear between checks!
Old Feb 6, 2009 | 07:19 PM
mildly retarded
oh, and its not effected by ambient air temps either!
Old Feb 6, 2009 | 07:21 PM
Actually there are many more advantages to using nitrogen. I have been in aviation maintenance for over 25 years. The use of nitrogen is used in shocks, struts, accumulaters, tires, etc... It will hold a more constant pressure under hot or cold conditions. The molecules are larger and do not leak past seals, o-rings and inner tubes like air does. Nitrogen is dry, using air also induces moisture into anything you put it in, even with a water seperator.
Soo, since I keep nitrogen bottles at my hangar for aviation related work, its all free to me and to any of my friends who need or want some
I see alot of planes that do more sitting than flying. Those who use air are always adding and the ones with nitrogen do not unless they have a forien object or hole in the tire. Do what you want, but i'll continue to use nitrogen.
Old Feb 7, 2009 | 02:08 PM
steve.g's Avatar
We use a similar system in trucking.Its a small pressure sensitive transmitter,mounted in the valve cap that will warn you (by a dash light) when a pressure change is detected.Great idea on an 18 wheeler,but is it worth it on a bike?
Old Feb 9, 2009 | 02:08 PM
It will hold a more constant pressure under hot or cold conditions...
Yes, but you're comparing wet air to dry nytrogen. Dry air and dry nitrogen expand and contract exactly the same due to changing temperature.
The crap a tire shop is filling your tires with isn't pure or dry nitrogen, maybe 90% nitrogen. Maybe not much more than the nitrogen you're breathing now. They're also not purging the air out of your tires beforehand. Also as the oxygen leaks out of your tires faster, the % of nitrogen will increase.
It does perform better in some ways, like slower leak rates, but most of the benefits are exaggerated or invented entirely.
One of those benefits is easy and safe portability. It can be liquified relatively easy at room temperature (~1500psi), so a lot of it can be stored in a very small space compared to the same quantity of air. And as a liquid which is basically not compressible, it's not going to explode like an atomic bomb if the bottle is knocked over.
Old Mar 16, 2016 | 09:09 PM
Bustin's Avatar
Bustin is on a distinguished road
Whatever you need to do to keep your tires inflated to the proper specs is the smartest move. Debating nitrogen or air is a distraction, if you don't invest in a good pressure gauge that doesn't **** you off every time you try to wedge it in past the brake rotors. Also, find an air chuck that gets into both front and rear wheels, without trying to tear out your valve stems or remodel your knuckles in the process . Like any other regular maintenance, having the right tools on hand makes it so much easier to stay up on tire pressure.
If you find yourself putting off checking tire pressures every couple weeks , or avoiding topping up to optimum pressure because it's a pain in the ****, you are very likely going to wear out your tires prematurely, regardless of what gas you chose fill them with. Tire prices keep going up and UP again, so paying attention to your tire pressures on the reg is smart money.
Old Mar 17, 2016 | 04:14 AM
One word: angled valve stems.
I fill my tires with a precise mixture of 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.039% carbon dioxide, and small amounts of other gases. Only troglodytes use common air these days.
Old Mar 17, 2016 | 05:27 AM
finepooch's Avatar
going all the way back to the original post from 2009, that web site sucks
i tried a cheap tpms a few years ago. they were valve stem caps that contained a sensor and transmitter. they were garbage. they let air out themselves, thus increasing my required effort to maintain air pressure.
Old Mar 17, 2016 | 06:06 AM
Yeah, but they let you know about it, right?
Old Mar 17, 2016 | 10:40 AM
AndyMX47's Avatar
Amazing coincidence - I use exactly the same stuff in my tires, but I bet I have you beat - I get mine for FREE!
Old Mar 17, 2016 | 12:12 PM
I have a special tank in my garage in which I mix and compress my own, so...
Old Mar 17, 2016 | 06:46 PM
Me too. However, I get a few more gasses mixed in during taco night.
Old Mar 17, 2016 | 06:58 PM
Light a match!
Old Mar 17, 2016 | 08:31 PM
Meier Link's Avatar
That one guy
I know this is an old quote but new people are reading this so I figure I should address it. While this is partially true the main reason people use Nitrogen is because of the lack of moisture it resonates under rapid fire. Oxygen gets extremely cold and causes excessive moisture in barrels and on the bolt which can result in ball chops or freezing of the internals of the marker which is never a good thing seeing top end markers also have electronics integrated into the marker.
Also the tanks used for Nitrogen last longer and also hold a considerable amount more pressure then the oxygen Tanks so there is less time at the refill station.
Old Mar 17, 2016 | 11:19 PM
And, don't forget the troglodyte thing.
Old Mar 18, 2016 | 04:36 PM
I use Nitrogen because it's better......... it's better because the tank is closer to the bike most days than the air hose which contains 79% nitrogen....
either way a pricy liquid filled 1/2 lb incremental pressure gauge is used to set tire pressures cold....and that I think is more important than the gas used.
Old Mar 18, 2016 | 04:51 PM
78.09% Nitrogen.
Old Mar 18, 2016 | 05:09 PM
78.09% Nitrogen.
I live in Texas, less smog, more Nitrogen less other gasses.....LOL
Old Mar 18, 2016 | 07:07 PM
finepooch's Avatar
you guys are full of methane
