compression vs. leakdown - weird results
Old May 27, 2008 | 11:49 PM
digitaledge's Avatar
digitaledge is on a distinguished road
Background -
I have had my VTR in storage for two years, carport under a cover. I live by the coast, and the salt air chews up everything. Got the bike cleaned off, test drove it, and dropped it off at the shop for a once over. Fluids, brakes, etc, all changed.
Test drove when I got it back, bike died, returned to shop, bad coil. Then it would not run, lots of testing including a compression and leakdown test. Compression came back as 110 lbs PSI on a cold motor, and leakdown as 4%. The mechanic could not get it running to get the motor warm. End result, bad vacum hose got cracked during tank removal and coil replacement.
Now I am wondering about the compression. Bike has 7K miles, I am responsible for half of them. A compression test of 110 PSI is not good, manual says that 160 PSI is what it should be, but a leakdown of 4% is supposedly very good. I am thinking that these two pieces of information contradict each other.
Any ideas here? The bike is rideable, and feels as powerful as I remember. I had a passenger, and I still roll on to 100 mph very easily. I am thinking that one of the tests is bad at this point.
Old May 28, 2008 | 04:26 AM
FTMS's Avatar
The leak down test is testing different things than the compression. I have seen a good leak down test with a low compression motor. The leak down test is testing more the oil rings on the piston than the compresion rings. You can have bad oil rings and still have good compression. The compression number is low, but I would ride it and put some miles on and then recheck it. A bike that has been sitting for as long as your did mite have a ring that is partialy stuck (aluminum piston/steel ring/salt air).
Old May 28, 2008 | 08:35 AM
killer5280's Avatar
Were both cylinders the same? If they were the same and the bike runs like it should, I wouldn't worry too much about the results of a compression test.
Old May 28, 2008 | 08:39 AM
Yes, both cylinders were the same according to the shop.
Old May 28, 2008 | 08:17 PM
And that's why you should do the tests with the motor warm! Your results WILL be off with a cold motor.
If you still think you have a stuck ring after getting a good, correct test then take some Marvel Mystery oil, about an ounce or so and pour it into each cylinder and leave it overnight. Then crank the motor with the plugs out and a towel over the plug holes to get the oil out. Reinstall plugs and restart. It will smoke a bit at first (understatement).
Old May 28, 2008 | 08:34 PM
Low compression with very little leak down sounds like valve timing problem.
Perhaps the timing chain slipped.
Old May 28, 2008 | 08:53 PM
Thumper's Avatar
Throttle must be wide open during the compression test as well to get a good result
Old May 28, 2008 | 09:16 PM
Did 100 mile break-in trip today, no issues. Did some city riding, got the temp up to "halfway" on the indicator (2000 VTR model). Overall, avg speed was 80 to 85 mph, hard to keep it there, wanted to go faster. Ended trip at the gas station I started at, averaged 34 mpg.
I don't think the compression test was done correctly. Does anyone have a recommendation for a compression tester? I would like to buy one online, and check again after a few more rides.
Old May 29, 2008 | 12:37 AM
With the way you say it's running (good) and the results of the leak down test (4%)... I'd guess that the compression test was bogus. It's kinda weird that they could correctly do a leak down test but botch a compression test...
Old Jun 1, 2008 | 07:18 PM
Maybe their compression gauge got run over by a car before they did the test.
barncat
Aug 20, 2012 07:46 AM
smokinjoe73
Feb 24, 2012 09:30 PM
crazybrit
Dec 14, 2007 08:28 PM
AZZKIKER
Feb 9, 2007 04:38 AM
Hawkrider
Oct 31, 2006 06:35 PM
