Coil on cap redo
Old Apr 17, 2015 | 05:18 PM
Coil on cap redo
So after butchering my original plug boots, I have acquired more to retry.
It seems I am the only guy who has CBR 600 coils instead of the 1000s.
Here is a pic of what I have. I began grinding to make the thin lower part long enough to reach the plugs. Problem is I hit metal of some kind and don't want to kill these coils.
Has anyone used these coils & have pics of the mod?
Old Apr 17, 2015 | 10:41 PM
https://www.superhawkforum.com/forum...04/#post278584
98VTRrider reported in my coil on cap thread he used 600 coils
Old Apr 18, 2015 | 09:18 PM
Erik, if you look at the coils I have pictured, they are quite different from the ones you have pictured in your thread.
The base seems shorter and the whole coil shorter on mine. When mine are fully seated on the plug the very top of the coil is below the capped off air valve on the head of the motor.
In your pic your coil can clear it enough to have the coil at 90* to the rubber base.
Old Apr 18, 2015 | 09:41 PM
Yes, but I linked you to the users post that said he used coils like yours....
Old Apr 18, 2015 | 10:13 PM
Mine are supposed to be 600 coils and I had no issues setting them up
Old Apr 19, 2015 | 04:18 AM
sjscicluna's Avatar
Whats the denso id on the top of the Coil
Old Apr 19, 2015 | 07:07 AM
8541, you adapted the stock boots to fit? I am finding the lower part that is to be ground down too short to reach the plugs if I leave enough rubber to be waterproof.
Did you grind the coil, cut the boot or both?
Old Apr 19, 2015 | 03:55 PM
sjscicluna's Avatar
i just Cut my boot and stretched it over the coil but didn't but it over the widest section ill need some time as work is busy ill have a look tonight for you and take a photo.
i did have some issues getting the coil to reach but i just pushed up the rubber on the lower part of the coil and they went on with a lil bit of force.
Old Apr 19, 2015 | 05:41 PM
I did a bit of both. I'll try to go out and get some pics but Though I haven't talked about it here, I have been fighting a couple of medical conditions the last couple of years and sometimes it takes a while to get stuff like this done anymore.
I do remember that I got the upper part of the boot to fit and then had to trim off some of the lower round bit to get engagement on the plug.
Been running them for about 3-4 yrs now with no issues.
Old Apr 19, 2015 | 08:22 PM
Thanks man, sorry to hear about the health thing. Feel better.
I am hung up on this booth thing since my last heavy rain rides I could feel the misfires from the wetness.
Old Apr 20, 2015 | 04:04 AM
sjscicluna's Avatar
Mine are 1000cc thats why mine are longer..
Honda CBR1000RR Ignition Coil SET OF 2 Coils 04 05 06 07 Denso 129700 4840 | eBay
Old Apr 23, 2015 | 11:43 AM
Not a great day for pics here but hope this helps.
In the head mine look like this:
Old Apr 23, 2015 | 11:45 AM
and this is how much you have to butcher the stock bit to get there:
Old Apr 23, 2015 | 01:15 PM
Hangfly's Avatar
Another pic for comparison.
Grind man, grind.
NZSpokes
Jun 3, 2015 05:43 AM
reaper
Jun 22, 2013 08:53 PM
chemomche
Jan 20, 2013 01:00 AM
chemomche
Apr 21, 2012 06:10 AM
Mark S
Jun 18, 2008 07:08 PM
