Is it the clutch? What's with turning right? HELP!
Old Jun 23, 2007 | 06:54 AM
LT01SH's Avatar
LT01SH is on a distinguished road
So I just bought a SH from a friend of mine and he said it had a few problems. The bike has 40,000 miles on it, but is in great condition minus these issues:
We think the clutch might be going bad. When starting out in first, the bike vibrates/rattles/chatters (whatever you want to call it) really hard. The noise seems to be coming from the tail of the bike due to its bouncing up and down. I read you can check for slippage by rolling on the throttle in 6th gear...I'm heading out to try that later.
Also, I know the SH is hard into 2nd...but unless I shift incredibly fast out of 1st and into 2nd, it won't go into 2nd at all. The lever just doesn't move. If I try long enough, it eventually goes in, but most time I have to let the clutch out and try again from 1st.
And just a side question...did anybody else have a problem with the high beam turning on when the handlebars are turned all the way to the right? It doesn't happen to the left.
Old Jun 23, 2007 | 08:13 AM
LT01SH's Avatar
in addition to my previous post
Oh, and I forget to mention...when in 1st gear and completely stopped, the bike likes to slowly roll forward even when I'm holding the clutch fully. That with the other problems give us reason to think the clutch is going bad.
Any feedback would help! Thanks.
Old Jun 23, 2007 | 09:52 AM
Arctic Fire's Avatar
Arctic Fire is on a distinguished road
Clutch clutch clutch.. check sixth, i just went through this and mine was toast at 55,000km
Old Jun 23, 2007 | 11:01 AM
LT01SH's Avatar
How much did it cost you to get it fixed?
Old Jun 23, 2007 | 11:13 AM
johnnyhonda's Avatar
johnnyhonda is on a distinguished road
kind of sounds like a transmion problem to me.
Old Jun 23, 2007 | 11:20 AM
Josh's Avatar
Minimal Post
Josh is an unknown quantity at this point
Do you have heli bars? Your highbeam may go on when turning all the way to the right with heli bars.
Old Jun 23, 2007 | 11:24 AM
check out ronaryes.com or parts unlimited.
Old Jun 23, 2007 | 01:48 PM
Try bleeding the clutch first. It's not easy or fun but with the aid of a Mity-vac it's significantly easier.
Old Jun 23, 2007 | 04:18 PM
I bled mine out, which helped dramatically, but I still had slip in the 6th roll on.
I had mine done at a dealership because I don't have the time, think it cost about $160 or so.
Old Jun 23, 2007 | 08:48 PM
Scooberhawk's Avatar
Señor Miembro, Ay Caramba
Yeah, I'd bleed the clutch before doing anything else.
Old Jun 25, 2007 | 03:19 PM
XLSR-VTR1's Avatar
XLSR-VTR1 is on a distinguished road
yeah but a clutch isnt expensive and after that many miles, what the heck.
Mine would pulsate through the lever when fanning it out on hard launch's so I put new in plates, while at it I put Barnett springs in there too, been good ever since.
Now on my ride yesterday, I buddy was out with us on an R1 and was complaining about shifting issues, vibration and all kinds of weird stuff... so we looked it over and found the chain was tight, really tight! So we backed it off some and the problems went away... I always keep my chain a little loose from what most people say but when I raced thats what everyone said to do, allows more room for the suspension to work unimpeded. I keep it adjusted to where it just will touch the guide on the bottom of the swingarm and not touch the mid pipe that came with the slip-ons.
Old Jul 15, 2007 | 09:50 PM
BLAKCK HAWK's Avatar
BLAKCK HAWK
WHAT'S SO HARD ABOUT bleeding the clutch, am i missing sumthin I PLAN ON DOING that cause my fluid is dark. brake dark also.
my caps is on, not yelling.
thanks
Old Jul 16, 2007 | 10:52 AM
Just a regular bleed isn't hard. It's when you get air in the system is when it becomes a PITA.
mduck
Oct 8, 2013 09:14 AM
Fozzy Bear
Jun 8, 2011 08:19 AM
Rollin20z
Mar 21, 2010 09:38 PM
Les
Dec 29, 2006 01:35 PM
W-O-T
Oct 7, 2005 06:03 PM
