CLUTCH NOISE
Old Nov 21, 2013 | 10:54 AM
superhawk99's Avatar
superhawk99 is on a distinguished road
CLUTCH NOISE
I'm interested on opinion on what's considered excessive clutch noise. I have a slight tick to a soft grind in the clutch basket housing but when I engage the clutch noise completely goes away. I'm thinking weak springs causing friction plates to rub on clutch plates. Not sure. Any input is mucho aprecciatooo :-D
Old Nov 21, 2013 | 12:01 PM
Letsrideinsc's Avatar
Letsrideinsc
Interesting. I just recently noticed some noise on hard launches, it sounds like it's being stressed, I'm at 40k, and this just started. It's a quiet noise that I'm having trouble describing something like a light grind, but it's gone once the clutch is 3/4 of the way out. I'm simply attributing it to wear and old springs, I ride pretty hard so I may just have a worn clutch. I don't experience it in other gears, just on launch.
Old Nov 21, 2013 | 12:10 PM
Very interesting read. I really only hear mine in neutral with clutch disengaged. Once I engage to shift into first noise goes away.
Old Nov 21, 2013 | 12:15 PM
CrankenFine's Avatar
I must be dyslexic... I always thought the clutch was "engaged" when the lever was fully released and "disengaged" with the clutch lever pulled in.
Maybe the clutch just needs bleeding? That's where I'd start anyway...
Old Nov 21, 2013 | 12:17 PM
Maybe he's saying when the clutch lever is engaged. 'Cause when the clutch lever is engaged, the clutch is disengaged, and vice versa.
Old Nov 21, 2013 | 12:24 PM
Jack Flash's Avatar
Well take off, eh.
What you're hearing is natural clutch noise, IMHO. When your engine idles, especially twins, it's natural vibrations from the clutch. When you engage the clutch, it stops. I wouldn't worry about it at all.
Have you ever heard a Duc at a street corner ? He could be waiting for the light to turn green on the other side of the street, and I can hear his clutch clacking.
Yes but when seeking technical answer we should state what's technically correct. So either I have it backwards or the OP does.
Old Nov 21, 2013 | 12:33 PM
I was being a smart-***. Technically speaking, you're correct, but in the words of Adam Savage, "I reject your reality and choose to substitute it with my own"
Old Nov 21, 2013 | 12:41 PM
Lol ok let me clearify sorry . When the clutch lever is not touched or sqeezed I havw the noise. Once I sweeze the clutch lever the noise goes away.
And JackFlash your right. Duc are noisy as hell. Lol makes sense.
Old Nov 21, 2013 | 12:43 PM
Thanx all for the replies. My first superhawk and I'm excited!!
Old Nov 21, 2013 | 12:50 PM
In that case your SuperHawk acts just like mine.
Old Nov 21, 2013 | 12:57 PM
and thats normal for the hawk?
i have a short video i made just gotta upload somehow if vids can be uploaded here
Old Nov 21, 2013 | 04:11 PM
99Shawk's Avatar
99Shawk is on a distinguished road
Mine does the same, and I had the same initial reaction as this was my first hawk too.... "Oh s***, what is wrong."
No need to worry, it's natural... Mine does it, my dad's VFR does it, my sisters ninja does it.
Old Nov 21, 2013 | 04:34 PM
Very good to hear!!! I was ready to drain oil and start digging lol
Old Nov 22, 2013 | 10:22 AM
You should hear mine, I have removed the anti rattle gear from the primary drive, and manual CCTs.
Both of these add to engine noise from the Right hand side.when I first put the bike back together after these changes I was really worried that something was wrong.
Now 20,000Klms down the track I am used to it, however I have noticed that it gets worse if my carbs are out of sync. It does get quieter when the clutch is pulled.
I have heard louder noises coming from other Hawks and have accepted that our bikes are mechanically noisey.
On other forums I have read where others have replaced all sorts of things in relation to clutch noises only to have the noise return in a short period .
Lots say that loud pipes get rid of these noises.
A friend of mine said to me once that Ducati owners would pay a fortune for that noise, and that I was lucky to have it for free!!!
FL02SupaHawk996
Aug 9, 2010 12:56 PM
mxer363
Jan 5, 2010 01:19 PM
Sandigee
Sep 30, 2009 11:19 PM
SuperHawkins
Oct 11, 2008 12:05 PM
duran
May 24, 2007 10:26 PM
