Clutch Issue
Old Aug 19, 2013 | 03:12 PM
HawkRider98's Avatar
Clutch Issue
Installed a FP star kit, everything looked good. When finished discovered clutch lever was frozen. Turned out bleed screw had gone bad and crap had frozen up piston in slave cylinder. Replaced slave cylinder assembly, bled with quick bleed valve and lever still frozen. Pulled pressure plate, discs and plates. Still no clutch lever movement. Suggestions?
Old Aug 19, 2013 | 04:52 PM
saige's Avatar
the boss
did you pull the clutch rod out,i have seen them bent,and maybe that could be causing the issue.
and how is your master cylinder.
Old Aug 19, 2013 | 05:00 PM
Looks like I had a piece out of order in clutch install. Havn't put it together yet, after I eat, but looking at diagram in manual, had a brain fart during install.
Old Aug 19, 2013 | 07:18 PM
Fixed. Now trying to get HID installed and working
Highfly
Mar 29, 2012 09:32 AM
shwinny
May 3, 2011 09:40 AM
cubdogg
Oct 20, 2010 12:30 AM
patience
Motorcycle News
Apr 13, 2010 10:31 AM
acarp
Sep 20, 2009 11:14 PM
