Clutch Issue
Installed a FP star kit, everything looked good. When finished discovered clutch lever was frozen. Turned out bleed screw had gone bad and crap had frozen up piston in slave cylinder. Replaced slave cylinder assembly, bled with quick bleed valve and lever still frozen. Pulled pressure plate, discs and plates. Still no clutch lever movement. Suggestions?
did you pull the clutch rod out,i have seen them bent,and maybe that could be causing the issue.
and how is your master cylinder. |
Looks like I had a piece out of order in clutch install. Havn't put it together yet, after I eat, but looking at diagram in manual, had a brain fart during install.
Fixed. Now trying to get HID installed and working
