clutch doesn't work after changing chain
Old Apr 15, 2011 | 09:44 PM
DriftingMustang's Avatar
DriftingMustang is on a distinguished road
So i changed my chain and sprockets. put the slave cylinder back on, never touched except to take it off and put it back on. pulled the clutch lever and it gave no resistance. well, me and my buddy fiddled around a bit and have determined that the master cylinder took a crap it wont suck down any fluid put into it, barely puts pressure through the lines.
the question is did i or am I doing something wrong or is this just coincidental bad luck.
Old Apr 15, 2011 | 09:53 PM
fred's Avatar
Mid-level Member
fred
bleed the line. you probably got air in there.
Old Apr 15, 2011 | 10:04 PM
tried, but the master seems not to be giving any pressure and sucking anything from the reservoir. i push in the slave and fluid sprays out the bleeder, i close that and the system pressurizes and goes shooting back out the reservoir of the master (in my friends face lol).
Old Apr 15, 2011 | 10:35 PM
fred's Avatar
Mid-level Member
fred
do you have a mighty-vac or some way to put a vacume on the on the bleeder at the caliper? you might have a lot of air that's hanging in the line and just pushing from the master cylinder won't do the trick.
Old Apr 15, 2011 | 11:17 PM
nykuryu's Avatar
nykuryu is on a distinguished road
something that worked for me on my calipers was open the res cap and zip tie the lever closed over night. brakes never felt better after that.
Old Apr 16, 2011 | 05:46 AM
Bluesuperhawk83's Avatar
Ive always zip tied the clutch handle in. I forgot who said to do that but ive never had issues when ive done it like that.
Old Apr 16, 2011 | 06:51 AM
Zip tie-ing the lever won't work at this point. What happened is that the slave cylinder worked its way out when you had the cover off to change the chain. This drained the reservoir and sucked air in. If you have a mity-vac you can bleed the system by pushing fluid UP from the slave. Many people don't realize you can do this with a Mity-vac but you can. You basically fill the cup with fluid and pressurize the cup to push fluid in. Careful you don't pop a line off the setup and get fluid everywhere. Brake fluid and paint don't mix.
If you don't have a mity-vac you can still bleed the clutch the old fashioned way. It takes a while though, since clutch spring pressure is the maximum pressure you'll generate on the system to force fluid out the slave fitting.
Old Apr 16, 2011 | 11:37 AM
I dont have a mityvac, I've tried bleeding the lines but the reservoir just wont pull it down. I know cars very well and i am an aviation mechanic for a living but im new to bikes and ive never come across something like this simply because there's massive air in the system. shouldnt it suck down the fluid so it push's air out in the first place? thats how it always worked when i did stuff with my cars.
Old Apr 16, 2011 | 12:00 PM
Wicky's Avatar
If you've got a large syringe you could try sucking fluid down from the slave but keep the reservoir topped up.
Old Apr 16, 2011 | 02:00 PM
geekonamotorcycle's Avatar
So you opened the cap and left the brake down over night? that got the air out? If this is true I will do it tonight
Old Apr 16, 2011 | 08:15 PM
Once air gets in the master it's tough to get back out. You just have to keep squeezing that lever over and over, bleed, repeat. But you have to do it fairly quick to get the air to actually move in the line rather than rise back to the top. Try wiggling the clutch lever rapidly before you start to try to get some of that air to come through the reservoir.
Old Apr 16, 2011 | 08:28 PM
nykuryu's Avatar
ya, in theory the air wont be under pressure within the line and be able to rise to the resivoir (sp?) and escape. i do it every time i bleed anything (brakes) and have never had a problem.
Old Apr 16, 2011 | 09:41 PM
just bought a mity vac so yeah, ready to try tommorow and see how it works. the most boggling part to me is from my experience cars it should suck down from the reservoir regardless, air trapped or not.
Old Apr 17, 2011 | 07:21 PM
It will, but it's easier to go in from the bottom. Just don't overflow the res. It's pretty small. The main issue here is the relatively small force from the clutch springs acting on the system. If it were any brake system it'd be easy.
Old Apr 17, 2011 | 08:00 PM
I've heard to not to this... the reason being that brake fluid is sensitive to moisture, and if you leave it in the open it will suck moisture from the air and become less effective. Especially in Florida.
Old Apr 17, 2011 | 08:24 PM
nykuryu's Avatar
brake fluid is very sensitive to moisture. once you open a bottle of brake fluid its bad. however like i said ive never had any problems with this. also im not completely taking the cap off, just unscrew it all the way off and then tight just a tad so its more or less just sitting on top.
Old Apr 17, 2011 | 11:00 PM
Even if the brake fluid is actually doing just that, it takes a lot more than 24 hours for it to be a problem...
insulinboy
Oct 8, 2013 05:07 PM
BigJMerc
May 4, 2011 12:14 PM
Red_Liner740
Aug 18, 2009 05:51 PM
xecutech
May 13, 2007 12:11 PM
EngineNoO9
Sep 26, 2006 06:34 AM
