Changing clutch & brake levers
Old Apr 11, 2007 | 03:39 PM
xecutech's Avatar
xecutech is on a distinguished road
I have some black clutch and brake levers to replace my stock levers. They should be here tommorrow. How hard are they to install?
I don't want to pull them off and put the others on, or can't get them back on. I am also concerned with adjusting them after they are put on.
Have any of you done this project yet? On a scale of 1-10 how hard was it?
Old Apr 11, 2007 | 07:01 PM
xecutech's Avatar
Well, anyone? Going to go do a google search I guess.
Old Apr 11, 2007 | 07:02 PM
Randman's Avatar
Moderate-whore
I did it, so we know it is easy to do...lol...really is a simple procedure...
Old Apr 11, 2007 | 07:05 PM
xecutech's Avatar
Well, when you remove the old ones and put the new ones on, aare adjustments necessary?
Old Apr 11, 2007 | 07:22 PM
Well, the levers are already adjustable in case you didn't know.
Be sure and clean and lubricate the pivot points and also check the little rubber boots over the master cylinder piston (where the lever contacts).
Old Apr 11, 2007 | 08:12 PM
supertwinSH's Avatar
supertwinSH is an unknown quantity at this point
super easy.....remove and grease new levers pivots ..and replace.
Old Apr 11, 2007 | 08:47 PM
johnnyhonda's Avatar
johnnyhonda is on a distinguished road
A+++
Spoken like a true mech. I know I couldn't have said it any better.
Old Apr 12, 2007 | 01:23 PM
xecutech's Avatar
Well, I am heading home to try this. It looks like there is just 1 bolt to remove and just stick in the new lever and put the bolt back in?!
Should be easier than replacing the windscreen yseterday!
Those rubber grommets are a beeeaaaathc to take out!
Old Apr 12, 2007 | 02:30 PM
Grab them with needle nose pliers and spray some WD-40 in there to help loosen them up. They will tear if they are old. I usually don't take them out - just a visual inspection is fine to verify they are not cracked.
Old Apr 12, 2007 | 02:59 PM
xecutech's Avatar
Well, I put them on in 10 minutes. It was easy and actually fun turning wrenches on your own bike. Thanks for the advice and encouragement.
Now to find my next project....
Old May 13, 2007 | 12:11 PM
StoneJrW's Avatar
StoneJrW is on a distinguished road
I got a set of aftermarket black levers also. Mine has a zip tie on them. Did yours?
skokievtr
Jul 21, 2014 12:28 PM
newleader
Mar 9, 2012 09:18 PM
Randman
Oct 15, 2007 05:48 PM
CNI Dawg
Dec 1, 2006 10:13 PM
caffeineracer
Sep 23, 2005 06:27 PM
