Clutch basket locknut size?
Old Sep 14, 2008 | 09:08 PM
noof's Avatar
noof is on a distinguished road
I'm in the process of rebuilding a trashed 1999 sh engine, and I'm wondering if anyone knows offhand the size of the bolt holding the inner basket to the shaft:
http://images.powersportsnetwork.com...102_CLUTCH.gif
It's part 20 in there. The list says 24mm but I got a 1" 12 point socket (25.4mm) and that's not even close to big enough...
Oh, also, does anyone know the shaft-to-shaft spacing of the crankshaft to the intermediate (clutch) shaft/axis?
Old Sep 15, 2008 | 09:50 AM
RickB's Avatar
Its either 30 or 32 mm iirc - You can try searching old posts, i have seen it mentioned on here a few times.
Old Sep 15, 2008 | 10:56 PM
noof's Avatar
30mm it is (at least for the 1999 engine.)
Incidentally, this is the reason I'm tearing down the engine:
http://anrp.net/bike/sh/perforated/
A casual glance at the bits says that everything except the piston is fine.
Old Sep 16, 2008 | 07:59 AM
RickB's Avatar
Yep, thats definitely a problem...
Old Sep 17, 2008 | 08:38 PM
noof's Avatar
A more thorough inspection says the bore in question is destroyed
So, I bought the bike with two engines, but I assume I can't mix and match top and bottom cases unless the bearing sizes match (unlikely, but it could happen.) I've heard about some cylinder replating/welding services but that's probably not worth the hassle...
CruxGNZ
Sep 29, 2014 01:31 PM
niteridder64
Feb 18, 2013 10:23 AM
jibbs
Oct 14, 2011 02:44 PM
acarp
Sep 20, 2009 11:14 PM
kayla
Jul 9, 2008 02:40 AM
