bend levers?
Old Sep 3, 2008 | 05:20 PM
finepooch's Avatar
bend levers?
i reading up on the buell peg mod. i'm gonna do it. question though: what's involved in bending the brake and gear shifters? they are too high for me with the stock pegs and with the buell pegs i will have to lower the levers a lot. i'm thinking that bending them might be the way to go. i also think that they won't bend down, they'll tend to bend side to side. should i consider cutting and welding them?
Old Sep 3, 2008 | 05:32 PM
I don't think I would bend anything right off. I would use the vast adjustability of the linkage and the spines on the shifting arm to attain a proper feel. Bending, cutting, welding may be a difficult answer to an easy situation.
Old Sep 3, 2008 | 08:15 PM
filter69's Avatar
Thats Mr Dill hole to you
i took a map gas torch and heated them to melding point (ish) and slowly bent them in stages (do not attepmt if your not versed in brazing or some type or metal charartistics)
and dont try to bend cold it will open up stress points and fissures in the aluminum
if ya get em hot it will relive the internal stree or the metal and allow them to be bent to a decent angle i would not try this on the bike remove them and put them in a vise with something to protect the metal from the jaws good luck and you mileage my vary
Old Sep 4, 2008 | 12:17 PM
PUSHrod's Avatar
Brake lever has a connecting rod. Try adjusting that, or if the range isn't enough, a new one would be easy to fabricate to the correct length. Cheap, too. The shifter is splined, refer to the above post.
Old Sep 4, 2008 | 04:50 PM
finepooch's Avatar
heat huh... i'll take my propane plumbers' torch to it.
i adjusted the shift lever down two splines and it started hitting the exhaust braket and i could not down shift. i put it back up one and it's still too high. i haven't tried the brake lever bedause i think it will be much the same story. so, i'm thinking bending is the answer.
Old Sep 4, 2008 | 07:01 PM
Don't adjust splines. That's old school. The linkage has two locknuts on it. Loosen those and rotate the Al rod so the shifter moves up or down.
Old Sep 11, 2008 | 03:51 PM
finepooch's Avatar
got the buell pegs on there. they're an improvement.
as predicted, the pedals are too high. the gear shifter is bad and the brake pedal even worse. i have to lift my foot off the peg to get it onto the brake.
so, what's the fix? i'm thinking either bend, or cut and weld an angle into them.
Old Sep 11, 2008 | 05:29 PM
Don't bend or cut anything:
https://www.superhawkforum.com/forum...ad.php?t=10161
Adjust it..
Old Sep 12, 2008 | 12:41 PM
finepooch's Avatar
brake pedal?
Old Sep 12, 2008 | 01:02 PM
finepooch's Avatar
i just read the whole thread. one spline is not enough. it doesn't drop the lever low enough. i still feel like i'm straining to upshift. i tried two splines but the exhaust bracket would not let me down shift. two splines is perfect for my gixxer.
so, i'm back to trying to figure out how to lower the levers A LOT.
Old Sep 13, 2008 | 12:43 AM
shayne's Avatar
I know a guy that just tried this, and he had the same problem as you he tells me. He could not get the adjustment he needed.
Old Sep 13, 2008 | 07:05 AM
finepooch's Avatar
i'll figure it out.
Old Sep 15, 2008 | 04:16 PM
finepooch's Avatar
a guy i play hockey with is the welding prof at the local college. i contacted him today and he said he'd weld up my levers. i'm gonna drop in to show him the bike and let him determine the best way to proceed.
Old Sep 15, 2008 | 04:51 PM
So the combination of adjusting the connecting rod and moving splines wasn't enough to give you what you need?
keep us informed with what you end up with.
Old Sep 15, 2008 | 08:25 PM
superbling's Avatar
I ran a set of kawasaki footpegs in the exhaust mounts (thread is somewhere around here.....) that I believe were even a tad lower than the buell mod and I was able to adjust the shifter to work. I also adjusted the brake pedal as low as possible but still had to raise my toes a tad to apply it (when I do use it). It quickly became second nature to do that and became a non-issue.
Old Sep 17, 2008 | 04:27 PM
finepooch's Avatar
i went to the welding prof's place tonight. he said he could ad a bit of aluminum plate to the pedals and get them lowered. i mentioned cutting a v notch out of the pedals, butting the ends back together and welding it up. he thought that sounds possible too.
i also asked him about welding bosses or spools on the bottom of the swingarm. he didn't like that idea because it will weaken the aluminum that makes up the swingarm. he suggested drilling and tapping the end of the extruded piece of the swingarm. he figures that would be stronger. has anyone done done this? did it work? got pics?
then he asked me to bring the bike by the college next week for more ideas.
Old Sep 19, 2008 | 05:35 AM
filter69's Avatar
I cut my exhaust bracket off down there with a saws all now i have all kinda clearance for my shifter but i did have to bend my kick stand **** forward a bit so i would stop trying to shift the kick stand (weird feeling)
Old Sep 19, 2008 | 05:56 AM
finepooch's Avatar
yeah, i noticed that kickstand is gonna be in the way when shifting.
cutting off the exhaust bracket isn't where i want to go. also, that wouldn't work for the brake side.
thanks for the input from all you fellas. keep it coming.
3D02
Nov 18, 2007 07:58 AM
xecutech
May 13, 2007 12:11 PM
3D02
Nov 6, 2006 09:40 AM
superbling
Nov 12, 2005 05:58 PM
superbling
Apr 26, 2005 07:53 PM
